Author Topic: wide angle mirrors?  (Read 3841 times)
rufiox426
wide angle mirrors?
« on: September 23, 2008, 12:45:33 PM »
anyone know a site i can get wide angle mirrors (power,heated) i found some on realoem.com but there 80$ i think.
wide angle mirrors?
« Reply #1 on: September 23, 2008, 02:37:13 PM »
For OEM ones, Pelican, BMA, the stealership, etc.
Other than that, no idea. I bought OEM ones from BMA, they were less than $80 but not the cheapest thing I've ever bought.
///m42 sport
wide angle mirrors?
« Reply #2 on: September 28, 2008, 09:43:05 PM »
Hey keep up updated.
I know the bmw catalog lists the wideangle mirrors with no heat at $30/side.
///m42 sport
wide angle mirrors?
« Reply #3 on: September 28, 2008, 09:44:17 PM »
Quote from: ak96ss;57238
How did the heat hook up?
wide angle mirrors?
« Reply #4 on: September 29, 2008, 02:06:05 AM »
If you want non-heated, that $30/side is probably pretty accurate.
I used part number 511 68 119 724 on both sides, RealOEM lists it at $79.52/ea. It will fit on either side, but you don't get the DOT-required 'Objects in mirror...' text on the passenger side mirror.
I hooked the heat up separately, since my car was not wired for heated mirrors from the factory. I ran a couple of wires through the door jamb to the defroster switch, so the heat only comes on when I have the rear defroster on. I believe that BMW has them wired so that they are on all the time (when the car is running), but I didn't see any reason to hook them up like that.
It's a heating element, so one wire to +12V and the other to ground and they are good.
ducatipaso
wide angle mirrors?
« Reply #5 on: October 01, 2008, 05:19:36 PM »
is that part number above for the wideangle? is this just a typical wideangle, or is it an 'aspheric' type mirror whereas the inboard side is flat, and the outboard edge arcs out?
