DISCUSSION
Swaps, Turbos, Buildups
head studs
Topic: head studs (Read 3156 times)
George77
head studs
September 20, 2008, 08:59:02 PM »
Hi guys,does someone know where I can get head studs from.Looks like ARP doesn't make studs for our engine or maybe I.m wrong.I.m a bit afraid to push it more without at least head studs.
12PSI of boost on stock engine
bearsbmw
Sr. Member
head studs
September 20, 2008, 11:31:14 PM »
14-15psi will be fine without studs... Headgasket is way more important!! I thanks you friend
rob_e30
Hero Member
-Receive: 1
head studs
September 21, 2008, 12:03:52 AM »
VAC sells ARP studs. It's the same as the M/S50 but uses fewer studs.
George77
head studs
September 21, 2008, 09:16:48 AM »
Thanks Rob ,are you sure the studs are the same?,do I need to modify them?
Boosted E30
head studs
September 21, 2008, 12:38:28 PM »
vacmotorsports has them for sure thats where i got mine i would get their steel head gasket to drop cp to 8.25:1 they told me it should be good for 20psi but ill see how that works out
rob_e30
Hero Member
-Receive: 1
head studs
Reply #5 on:
September 21, 2008, 01:07:58 PM »
I'm sure as I got my set from the. I went back to the stock HG after going through 2 MLS.
Boosted E30
head studs
Reply #6 on:
September 22, 2008, 07:15:05 PM »
ya im on my second MLS but thats cuz my head cracked the first one didnt even fail it was my own stupidity not watching engine temp
DISCUSSION
head studs
