Author Topic: Swapping M42's and have a few questions.  (Read 2991 times)
SheldonJace
« on: September 15, 2008, 01:38:49 PM »
Okay so I'm beginning to swap M42's out of my old 318is into my new one. While I have the motor(s) out I plan on doing a lot of other stuff that is otherwise easier while the motor is out.
This post was going to be longer and I was going to list the parts I already planned on ordering/ordered but I decided to keep it short for once.
So basically question is, What all should I replace/do to the motor while it is out of the car? Looking to do a small rebuild and nothing to intense.
Please post parts and where to buy them. Thanks in advance.
Sheldon.
Burnall4
« Reply #1 on: September 15, 2008, 01:53:40 PM »
1. Timing Chain
2. Water pump
3. All the gaskets (including Head if you like, its not that hard)
4. Rear Main seal
5. Clutch/Flywheel/throw out bearing
etc...
Just depends on how far you want to take it/$$$$/time
I buy most of my parts from
http://www.pleicanparts.com
http://www.bmaparts.com
and my local junkyard!
good luck take lots of pics and show your progress
Current BMW: Looking
Current Truck: 06 Chevy 1500 4x4 Crew Cab
Current Motorcycle: 2005 CBR 600rr (race bike)
1991 318is sold
1990 325is sold
SheldonJace
« Reply #2 on: September 15, 2008, 02:36:15 PM »
Quote from: Burnall4;56731
1. Timing Chain
2. Water pump
4. Rear Main seal
etc...
Sweet I already planned on the first 4 in your list. I don't know if I'll change the clutch as I'm using the one from my newer E30 and the previous owner claimed that it had been replaced recently (I guess we'll find out). But couldn't I just have my other flywheel resurfaced and maybe even shaved down? I maybe interested in the m20 flywheel conversion too...don't know yet though. Should I replace most of the Timing components like guides and tensioners and what not?
Thanks for the sites as well.
Anymore?
I think I'm willing to spend about 2k on parts.
SheldonJace
« Reply #3 on: September 15, 2008, 04:13:08 PM »
I also want to change out all the bushings and mounts to Polyurethane.
I know I'll probably buy the Motor and Tranny mounts from IE
but is there any other alternatives?
GrindCulture
« Reply #4 on: September 16, 2008, 02:16:20 PM »
Not sure if this is the case with you LHD guys but you could swap the rack over for an E36 or Z3 rack to sharpen it up a bit while the motor's out, pretty easy job and it makes a hell of a lot of difference.
E30 M42 Touring rightness!
SheldonJace
« Reply #5 on: September 17, 2008, 10:44:06 AM »
GrindCulture that would be an awesome upgrade but I'd have to find all the parts and read up on how its done. I've never really looked that much into it. Any DIY threads on the process???
I also should have mentioned that the motor I'm rebuilding has 140k miles on it and ran really well before I got in a car wreck with that car. It than sat from last January till now, and when my friends gave it a jump it fired right up on the FIRST turnover :eek:. They let it run for a while and took it around the block and then drove it from my parents house to my friends place in town where we'll be doing the work (40 miles) with no problems. So I'd say the motor is pretty strong still but I want to do all this maintenance and rebuild so I don't run into problems (at least I hope) while I'm in college. I start college January.
So I'm going to make a list of parts and I want people to either add to it or help me know what I shouldn't have to replace. Most parts will be from BMA or Bavauto.
Here we go:
Timing Chain
Timing Chain Case Gasket
Timing Chain Case Gasket Set Lower
Timing Chain Case Gasket Set Upper
Timing Chain Cover Gasket Upper
Timing Chain Cover Gasket Lower
Timing Chain Guide Rail lower
Timing Chain Guide Rail left
Timing Chain Tensioner
Timing Chain Tensioner Guard
Cylinder Head Gasket Set
Valve Cover Gasket Set
Fuel Filter
Thermostat
Thermostat Housing Gasket
Thermostat O-ring
Water Pump
Oxygen Sensor
V Belt Power Steering
V Belt A/c
V Belt Alternator
Oil Filter
Sachs Clutch Kit
Rear Engine Seal with Gasket
All new Redline fluids throughout
BMW Coolant
K&N Drop in Air Filter
What else should I add?
I really want to do a dual or single electric fan setup too but can't think of any companies to look for?
« Last Edit: September 17, 2008, 10:48:36 AM by SheldonJace »
FredK
« Reply #6 on: September 17, 2008, 10:59:00 AM »
Quote from: SheldonJace;56862
http://www.r3vlimited.com/board/showthread.php?t=66247
Get the rack spacers from AKG Motorsport for $15. You do not need to modify the linkage on an airbag car. You need to open up the hole in the firewall around 1/2" down and towards the passenger side of the car to allow the steering shaft to pass through the firewall without binding.
