Author Topic: e36 turbo  (Read 9295 times)
strypt
e36 turbo
« Reply #15 on: September 11, 2008, 02:15:01 AM »
Sounds like your in for a surprise ;) Count on that everything will take twice as long and cost twice as much ;) at least...
e36mike
e36 turbo
« Reply #16 on: September 11, 2008, 02:49:10 PM »
hey bears
the m50 manifold is four bolts per exaust port and mine is an m40 so it only has two
it wont work but thanks for the idea:)
e36mike
e36 turbo
« Reply #17 on: September 11, 2008, 02:52:41 PM »
dont worry guys
things are a lot cheaper here by me
all the steel to make a manifold is only 50usd so if i mess that up too it wont be a big loss
besides whats the fun in buying everything and just bolting it on:D
i will have some pics soon
ludiagsm
e36 turbo
« Reply #18 on: September 13, 2008, 03:03:01 AM »
here is some old pictures  and a two new of mine e36 316 m40 turbo maybe you can use them for ideas to make your own m40 turbo :)
here is  two from last week :
ludiagsm
e36 turbo
« Reply #19 on: September 13, 2008, 03:12:39 AM »
when you making the instalation of  extrainjectors with aluminium fittings  make them with two inturnal diameters  first must be 13mm and second with 14,2mm the second diameter  must be deep 10mm  ,fitting must be long 30mm and in the and you must cut it to angle to make write fit  to manifold
hope you uderstand sorry for my bad einglish:)
e36mike
e36 turbo
« Reply #20 on: September 16, 2008, 12:48:01 AM »
what car is the second fuel rail from?
did you make it ?
George77
e36 turbo
« Reply #21 on: September 16, 2008, 06:03:09 PM »
Hi,sorry for the off topic,Iudiagsm how much boost are you running in that M40,do you have any internal mods?
12PSI of boost on stock engine
e36mike
e36 turbo
« Reply #22 on: September 17, 2008, 12:58:25 AM »
hi george
you can see on his own thread its under turbo swaps the topic is called HI THERE
im sure you will find all you need to know
but just for info he is riding 0.7 bar
ludiagsm
e36 turbo
« Reply #23 on: September 18, 2008, 07:39:38 AM »
Quote from: e36mike;56778
did you make it ?
you may use from e30 or e36 original fuel reil for 4 cil engine second hand .
ludiagsm
e36 turbo
« Reply #24 on: September 18, 2008, 07:42:02 AM »
Quote from: George77;56831
before i am runing on 0,7 bar but  for over 30 000k kilometers write now 1,2 bar peak 1 bar hold original CR with no inturnel mods original pistons rods and bearings , i use only MOTUL 20w60 lioman motor oil i recomend that to everyone!
« Last Edit: September 18, 2008, 07:45:14 AM by ludiagsm »
e36mike
e36 turbo
« Reply #25 on: September 18, 2008, 01:48:24 PM »
Quote from: ludiagsm;56931
do you have to make it wider because my spacing not right
ludiagsm
e36 turbo
« Reply #26 on: September 19, 2008, 01:38:28 AM »
Quote from: e36mike;56955
yes my friend make some welding work to make right fit
