Author Topic: Rearview Mirror Oooops  (Read 4460 times)
tskoda
« on: September 05, 2008, 09:29:22 PM »
I was replacing the stock mirror with a map light unit, and when I went to twist the old mirror out, the plate that it snaps into (and WAS mounted to the car) popped out.
RealOEM refers to it as a base plate.
How the heck can I get that plate re-mounted? It doesn't just snap back into place; it appears to have been pressed onto the underside of the roof originally.
Anyone else experience this or have any (helpful) thoughts?
Thanks
Tom
Matt-B
  • Administratorz
« Reply #1 on: September 06, 2008, 10:47:53 PM »
I took just the mirror part off, and pulled as much wire out as i could and snapped mirror part on to old knob, and wired it to my cigarette lighter cause its a constant power.
My did not want to come off lol
-mA+t B
tskoda
« Reply #2 on: September 07, 2008, 04:16:50 PM »
Quote from: matthew-mayhem;56179
Sage advice, but alas too late.
Isn't it annoying having a wire hanging there?
Matt-B
  • Administratorz
« Reply #3 on: September 07, 2008, 07:35:43 PM »
Well what i did was use electrical tape and it blends in, I have a gps under it so it all blends in.
-mA+t B
Vladi
    • http://www.bmwzone.ro/forum
« Reply #4 on: September 08, 2008, 12:15:40 PM »
That happened to me also...very frustrating. Drilled the rivets out and placed it back in with 3 screws and glue. :) Been working fine for 3 years. :)
tony92ic
Other options:
« Reply #5 on: September 12, 2008, 09:23:28 AM »
Get a mirror from an e46 BMW. You'll get map lights and the amber night illumination. Or I used a 95 Mustang convertible mirror on my e30 convertible. It has map and a dome light built in.  Both glue to the glass instead of using the pop bracket.
Or you could try JB Weld on the bracket. May be strong enough to hold.
Tony
92 e30 318ic - Why I am here
72 2002tii - Much modified
91 M42 - Am I a hoarder?
