Author Topic: IS it Safe to Use Just a Single Electric Fan?  (Read 2313 times)
halcron
« on: September 02, 2008, 10:54:41 PM »
I am planning to remove both the AC condensor fan (the black electric fan at the front) as well as the clutch fan and install just a single electric fan for my e36 318is. The purpose is to reduce some weight and parasitic drag. I feel the condensorfan and its bracket causes quite a bit of odstruction to air flow and think it would be best to remove it.
If I am not wrong, cars these days should have just a single electric fan running instead of having 2 fans.
Do you guys think its safe to do so or do E36s strictly need 2 fans to operate?
Thanks!
Boyracer
    • http://www.jannousianen.net
« Reply #1 on: September 03, 2008, 03:43:29 AM »
I have run my E36 on track without any fans at all, no viscous or electric. With stock power it's not a problem unless you need to run engine long time without moving. After around 20-30 mph speed the wind is doing all the cooling and fan is liability.
« Reply #2 on: September 03, 2008, 10:10:20 AM »
Search "volvo fan swap"
Wizard
« Reply #3 on: September 03, 2008, 11:50:55 AM »
I did just the opposite. I deleted my clutch fan and just use my aux A/C fan. Even in Florida summer heat the gauge stays at 1/2. And as boyracer said, as long as you are moving no fan at all is necessary.
kowalski
  • El\' Duder
« Reply #4 on: September 03, 2008, 12:21:27 PM »
i've been running an electric fan with an auto on off temp switch for the past 3 years.
Sale:
Fore Sale Thread
