Engine oil?
Author Topic: Engine oil?  (Read 6904 times)
Engine oil?
« on: June 02, 2006, 06:33:02 PM »
What brand and weight oil do you use?
What weight oil would be ideal for 80-90 (sometimes even higher) degree weather? I'd also like to dampen the ticking as much as possible.
TIA
kramerica5000
Engine oil?
« Reply #1 on: June 02, 2006, 07:37:17 PM »
I'm using mobile 1 15w 50 right now and my engine is definitely noisy until it warms up when outsid temp gets below 60 degrees. But I think its a good weight for really hot weather, but only if your engine is doesn't leak any oil.
I'll prolly run 5w 50 either mobile 1 or Redline when the weather gets cooler.
Quote from: Eurospec
TIA
M42boy
Engine oil?
« Reply #2 on: June 02, 2006, 09:39:05 PM »
Quote from: kramerica5000
I've been warned to be cautious about running synthetic oil in older engines or it may begin to start leaking like the Titanic.  It's not definate, but a lot of people have had that issue.
If you've been running synthetic for years, keep using it, but I think problems can happen if you just make a switch with high milage.
I'm not saying don't do it, but proceed with caution.  I decided to stick with dino juice and I still got leaks, so maybe they are inevitable.
I'm using Shell Rotella T.  I like a heavier weight oil in this car (15w50).
sheepdog
  • Site Admin
Engine oil?
« Reply #3 on: June 02, 2006, 09:41:09 PM »
10w30 Castrol Syntech  (semi-synthetic) year round (0-105 degrees F.) with no problems. I rarely if ever get lifter noise. Usually I start to shortly after the indicator says it is time to chaneg the oil, which is around 8k.
Well to be honest, I had no issues untill my T-chain died, but that was due to slack and replacing the tensioner after it was too late.
Oh, and my leaks stopped when I switched from regular dino to Syntech.
Edit:Corrected dino to Syntech.
« Last Edit: June 03, 2006, 11:29:07 PM by sheepdog »
Choking Hazard
Engine oil?
« Reply #4 on: June 02, 2006, 09:43:45 PM »
I've got M-1 15W50.  I've tried heavier viscosity (this is alabama and it gets pretty hot), but it made the timing chain noisy.
[SIGPIC][/SIGPIC]-Scott
romkasponka
Engine oil?
« Reply #5 on: June 03, 2006, 07:17:40 AM »
valvoline VR1 racing 10W60 (sintetic)
E30 318is M42
E36 318is M44
Wizard
Engine oil?
« Reply #6 on: June 03, 2006, 07:29:19 AM »
I run the Mobil 1 Extended Performance 15W-50
Always warm or HOT weather in S.W. Florida...lol
I just like the convienence of being able to find it locally (Wally World, etc) and not having to special order high tech oils like Redline, Royal Purple etc....
M42boy
Engine oil?
« Reply #7 on: June 03, 2006, 08:50:11 AM »
For the ultimate in protection:
http://www.enjoythedrive.com/products/product_display.asp?product_id=1997
But, probably only Febi's engine is really worth using this.
kramerica5000
Good source of info on oil
« Reply #8 on: June 03, 2006, 02:39:51 PM »
I found this pretty informative:
http://www.carbibles.com/engineoil_bible.html
silverblades181
Engine oil?
« Reply #9 on: June 03, 2006, 06:43:21 PM »
Castrol Synthec 5W40   Next oil change I'll be running synthetic 20w50 for the summer.
E30 318is 1991 (Brilliantrot)
Bayerisch Motoren Werke
Engine oil?
« Reply #10 on: June 03, 2006, 10:19:23 PM »
I'm runnin 10w-30 at the moment.  I had it in for winter but I haven't had any issues in the summer so its going to stay for now.
M42Iberia
Engine oil?
« Reply #11 on: June 03, 2006, 10:24:09 PM »
Quote
Oh, and my leaks stopped when I switched to Syntech from regular dino.
x2:D
« Last Edit: June 03, 2006, 11:31:18 PM by sheepdog »
sheepdog
  • Site Admin
Engine oil?
« Reply #12 on: June 03, 2006, 11:28:04 PM »
Quote from: M42Iberia
x2:D[/quote]
Woops, that is actually backwards.
Mine stopped when I went to Syntech.
I actually went back to dino for one change to see if anything changed... The leak returned. Went back to Syntech and that is when the chain crapped out.  Only 2000miles on that oil. :mad:
« Last Edit: June 03, 2006, 11:30:54 PM by sheepdog »
Engine oil?
« Reply #13 on: June 04, 2006, 12:49:08 AM »
Here's an interesting find, choosing the right motor oil (According to climatic conditions in your area)
Looks like I'll be going with either 10w40 or 15w50.
mikesjo
Engine oil?
« Reply #14 on: June 04, 2006, 01:06:26 AM »
We have 10w40 in our cars. :). It's suppose to hit over 25 degrees celsius up here in Vancouver this summer though. Will 10w40 still be ok?
