I'm using mobile 1 15w 50 right now and my engine is definitely noisy until it warms up when outsid temp gets below 60 degrees. But I think its a good weight for really hot weather, but only if your engine is doesn't leak any oil.
I'll prolly run 5w 50 either mobile 1 or Redline when the weather gets cooler.
I've been warned to be cautious about running synthetic oil in older engines or it
may begin to start leaking like the Titanic. It's not definate, but a lot of people have had that issue.
If you've been running synthetic for years, keep using it, but I think problems can happen if you just make a switch with high milage.
I'm not saying don't do it, but proceed with caution. I decided to stick with dino juice and I still got leaks, so maybe they are inevitable.
I'm using Shell Rotella T. I like a heavier weight oil in this car (15w50).
