Author Topic: Oil pressure warning light  (Read 2865 times)
dbgrubbs
« on: August 26, 2008, 07:00:47 AM »
I'm having some issues with my warning light. It seems to glow at times and will suddenly disappear. I've even shut the engine off and restarted and the light has gone out. I really don't suspect low oil pressure but who knows. I really want to hook up a gauge to better monitor things. Is there a chance that the sensor is on it's way out? Is that common at all? I've already  opened up the oil pan and fixed the loose oil pump bolts around a year ago so I don't think that is an issue. Anything else I should suspect?
Thanks
Don
bmwpower
« Reply #1 on: August 29, 2008, 10:14:24 AM »
Quote from: dbgrubbs;55508
Thanks
Don
Better open up the pan again and check the gasket, too.  These bolts seem to loosen up pretty easily...1 year might be enough time.
EN318isPDX
« Reply #2 on: August 29, 2008, 11:18:56 AM »
oil pressure is serious business.. i wouldn't ignore it.
kowalski
  • El\' Duder
« Reply #3 on: August 29, 2008, 01:16:26 PM »
pull the sensor out and make sure its clean, and perhaps replace it. I had a faulty one about a month and a half ago.
Sale:
Fore Sale Thread
dbgrubbs
« Reply #4 on: September 01, 2008, 09:06:59 AM »
Decided to take the easy way out and try the oil pressure switch first. Yup, that was it, no more light.
Thanks
Don
