Author Topic: changing coolant hoses writeup  (Read 20784 times)
aworthybrother
« Reply #30 on: March 03, 2011, 11:13:14 AM »
Sorry to bump an old thread. Can somebody please help me pointing where the other end of these 2 hoses are connected? A picture would be great.  Please note I did not do the mess under the intake thing. Thanks.
rjcaptsean
« Reply #31 on: March 03, 2011, 01:26:57 PM »
I got lucky and found you a "before" shot.   If you draw a line (on your picture) from the yellow #2 to the yellow #1 you will see the opening of the hose that #2 connects too.  Should be a plastic 90 there.     #1 goes down to the Check valve on the Carbon Canister.
aworthybrother
« Reply #32 on: March 03, 2011, 02:34:11 PM »
Thank you.  Would you know where is the other hose on "90 degrees elbow" connected? The hose that goes underneath the intake manifold?  Realoeam doesn't show a clear picture where it is connected.  Thanks.
Quote from: rjcaptsean;101968
rjcaptsean
« Reply #33 on: March 04, 2011, 06:39:35 PM »
It snakes under the intakes and toward the front and comes up and connects to the valve cover.   In your picture, you can just see it directly to the left of the intake manifold.
