Author Topic: Ignition Lock  (Read 1774 times)
far4ngn
Ignition Lock
« on: July 21, 2008, 12:27:55 AM »
Any of you guys had problems finding the correct replacement ignition lock?
Mine failed inside and I've removed and approached BMW, they are stuggling to find the correct part even with the part number stamped on the side.
Any suggestions on how to track the part down...I've looked in RealOEM, just wondering if anyone had similar problems.
Cheers
Paul
nicknikolovski
Ignition Lock
« Reply #1 on: July 21, 2008, 03:54:22 AM »
Give us your VIN and i'll check it out for you.
Ignition Lock
« Reply #2 on: July 21, 2008, 04:47:22 AM »
I'm surprised they can't locate the correct one - even though there are 5 listed in RealOEM here: http://www.realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=32_0854&hg=32&fg=30 (looks like 4 if you want your key to match your other locks) they should still be able to order the correct one for your car in the parts system with your VIN.
OTOH, I know people that have intentionally ordered different ignition cylinders, so that even with the VIN and an unscrupulous dealer ordering a key, a thief would not be able to start the car....
« Last Edit: July 21, 2008, 04:49:40 AM by ak96ss »
