Recently I have been having ignition issues with my 318. It has the m42. I discovered that coil 4 was not firing. I tested the plug wires individually and they were all working. I replaced coil 4. Still no spark from coil 4. I swapped the plugs from coil 4 to coil 3 and tested for spark. This time coil 3 did not fire but coil 4 was.
Using a test light and a DMM, I tested the leads to coil 4.
+12 is good
GND is good
Continuity between pin 51 on the ECU plug and the plug to coil 4 is good.
Stomp test results in a 1271 code. This is the only code being thrown.
Correct me if I am wrong, but that means that coil 1 has a fault right?
Coil 1 works fine. Coil 4 does not. Am I wrong in thinking that this is a fault in the ECU?
Any help is appreciated.
