Author Topic: ECU Trouble  (Read 2844 times)
LPStandard
ECU Trouble
« on: July 13, 2008, 06:18:01 PM »
Recently I have been having ignition issues with my 318. It has the m42. I discovered that coil 4 was not firing. I tested the plug wires individually and they were all working. I replaced coil 4. Still no spark from coil 4. I swapped the plugs from coil 4 to coil 3 and tested for spark. This time coil 3 did not fire but coil 4 was.
Using a test light and a DMM, I tested the leads to coil 4.
+12 is good
GND is good
Continuity between pin 51 on the ECU plug and the plug to coil 4 is good.
Stomp test results in a 1271 code. This is the only code being thrown.
Correct me if I am wrong, but that means that coil 1 has a fault right?
Coil 1 works fine. Coil 4 does not. Am I wrong in thinking that this is a fault in the ECU?
Any help is appreciated.
1991318is
ECU Trouble
« Reply #1 on: July 13, 2008, 06:24:42 PM »
Quote from: LPStandard;53246
+12 is good
GND is good
Considering it switched to coil 3 didn't work when you switched them, I'd doubt its ecu. I'd switch them all around and try a new set if its still jumping around. Also check all of the grounds and all of the powers.
LPStandard
ECU Trouble
« Reply #2 on: July 13, 2008, 06:39:54 PM »
I didn't switch the coils, I switched the leads going to the coils. So from the ecu's point of view coil 4 was coil 3 and vice versa. The result was coil 3 (coil 4 as far as the ecu knows) not firing and coil 4 (ecu3) firing.
All powers good and all grounds good.
All 4 trigger wires have continuity to the correct pins on the ecu plug
nicknikolovski
ECU Trouble
« Reply #3 on: July 14, 2008, 03:39:46 AM »
You should replace all coils at once.
LPStandard
ECU Trouble
« Reply #4 on: July 14, 2008, 05:05:51 PM »
Quote from: nicknikolovski;53270
I know. But I am trying to save up for school in september so I couldn't justify 4 coils.
nicknikolovski
ECU Trouble
« Reply #5 on: July 15, 2008, 04:11:51 AM »
That's strange, what you mentioned above because if swap any of the coils to a different cylinder, the engine will misfire straight away. For a new set of coils your looking at $170 and a set of ignition leads $130 both from pelican parts or you can try BMA which may be cheaper with the M42CLUB discount.
LPStandard
ECU Trouble
« Reply #6 on: July 15, 2008, 02:21:22 PM »
I was swapping the leads with all of the plug wires removed from the head. Simply to test for a change.
