Author Topic: tickin noise  (Read 9104 times)
stitypera
tickin noise
« on: July 06, 2008, 05:06:38 PM »
three times i tried gettin it fixed costing bout 1400 and still not fixed,
its an annoyin tappety noise all mechanics say its hydraulic tappets
but it cnt be causin that, the lastest guy put 16 pullers in and he kept ringing the supplier tellin them it had no change they said to put bita mileage on them,that was done and no change,now he threw in few buckets and thats all i know at min as he still hasnt contacted me bout it any ideas lads,engine is good puller,oil pressure perfect only this annoyin noise driving me mental m42 318is engine 124000 miles on it
« Last Edit: July 06, 2008, 05:20:46 PM by stitypera »
tickin noise
« Reply #1 on: July 06, 2008, 05:11:38 PM »
« Last Edit: July 06, 2008, 05:16:11 PM by tjts1 »
stitypera
tickin noise
« Reply #2 on: July 06, 2008, 05:18:13 PM »
wats ur point tjts,ur name shud tit,if u got no decent reply then dnt bother
kenika65
tickin noise
« Reply #3 on: July 06, 2008, 05:24:00 PM »
Id be sure to replace your timing chain tensioner if you haven't allready.
Also be sure to run an oil additive like lucus or marvel mystery oil
stitypera
tickin noise
« Reply #4 on: July 06, 2008, 05:25:57 PM »
yea had lucas run through it last tym and only done bout 20 miles whe it cam back again,il tell him about the timing chain tensioner,but they all maintain its in the tappets area
Wizard
tickin noise
« Reply #5 on: July 06, 2008, 06:01:06 PM »
Quote from: tjts1;52738
http://grammar.ccc.commnet.edu/grammar/
+1    :D
EN318isPDX
tickin noise
« Reply #6 on: July 06, 2008, 06:11:23 PM »
big effing deal! he leaves out vowels! you guys gotta be abunch of haters. oh how i love the maturity of the internet. I'm guessing English isn't his first language.
kowalski
  • El\' Duder
tickin noise
« Reply #7 on: July 06, 2008, 06:50:09 PM »
its pretty tough to answer posts one can't understand. if the OP wants us to take the time to answer his question, then he should at least take the time to make the post understandable.
Sale:
Fore Sale Thread
250k318is
tickin noise
« Reply #8 on: July 06, 2008, 08:05:55 PM »
you may want to look into a exhaust leak mine is leakin a bit causina tick that comes and gose with temp
pifane
tickin noise
« Reply #9 on: July 06, 2008, 11:39:37 PM »
When you have this engine and this car, you have to realised that you have to run the windows closed, because this car make a lot of weird noise......ITS A TIGER TANK!!!
PIFANE.MONCHAR.COM
AcSchnitzer318is
tickin noise
« Reply #10 on: July 07, 2008, 12:06:01 AM »
Quote from: pifane;52775
Amen to that.  Can't find an exhaust leak for the life of me.  Removed exhaust header to inspect for damage/cracks.  Nothing found.  Replaced header gaskets (3).  No change.  Would a damaged cat or pipe on the exhaust cause a ticking after 4000 rpm?  Intensity increases with RPM of course.
Sorry for the slight thread jack.
stitypera
tickin noise
« Reply #11 on: July 07, 2008, 12:12:27 PM »
Take It You,s Haters Got No Short Text In Ur Thick Heads Hahahaha
Tensioner Is Perfect,rang Today Shes Losing Oil Pressure,he Thinks Theremmight Be A Bit Of Play Between The Shim And The Buckets
Wise Old Dog
tickin noise
« Reply #12 on: July 07, 2008, 01:43:54 PM »
Shims??? Did he say shims???
Are we talkin about hydraulic lifters?
IIRC there are no shims.
tickin noise
« Reply #13 on: July 07, 2008, 02:04:10 PM »
Quote from: stitypera;52824
I forgot my moronics to english dictionary at home. Anybody want to translate?
« Last Edit: July 07, 2008, 02:09:29 PM by tjts1 »
EN318isPDX
tickin noise
« Reply #14 on: July 07, 2008, 03:22:49 PM »
ok at first i defended this guy but... cmon now man you gotta take time to think before you speak... or type in some peoples case. If you car is losing oil pressure.... DROP your oil pan, check your oil sump pickup, check your oil pump, if you knew how to read you could do some research on this great forum and find that some people had issues with the bolts inside the lower oil pan getting loose and falling into the oil pan.
/END THREAD
/BAN +1
