Author Topic: Just bought a 91 318is for a DD  (Read 2272 times)
ejnight
« on: July 03, 2008, 01:17:41 PM »
It runs well. But seems to lack power. It gets up to speed but just seems a little weak. what should I check?
91 318is DD and 89 325is turbo.
Custom Made Skid Plates For M42
http://www.m42club.com/forums/showthread.php?p=93783#post93783
EN318isPDX
« Reply #1 on: July 03, 2008, 01:22:38 PM »
Fuel pressure, look at the "mess under the intake", Tune up (Ignition system, maybe an o2)
ejnight
« Reply #2 on: July 03, 2008, 01:31:44 PM »
OK the mess under the intake? do I spray looking for vac leaks? Or is there one hose that is more likely to be the one? How do I check fuel pressure with out special tools? i will check cap/rotor and replace plugs this weekend.
EN318isPDX
« Reply #3 on: July 03, 2008, 03:15:00 PM »
Quote from: ejnight;52536
There isnt a cap/rotor, its direct ignition. I've heard coils rarely go bad, instead of buying new plug wires for 100+ dollars and coils for 200+ dollars id recommend the COP kit. Checking fuel pressure should be the last thing you do, all you need is a fuel pressure gauge and i believe that autozone rents them for a deposit. Hose wise.... well normally all those hoses crammed under the intake get alot of cracks in them. Check out http://www.m42club.com/forums/showthread.php?t=2742
