Author Topic: m42 track build  (Read 26097 times)
HMS_Tim
m42 track build
« on: June 30, 2008, 01:13:41 PM »
I had originally posted this in off topic and realized it was not the place3 for this thread.  I am in process of building a '89 325i with a '93ish m42. Lots of various mods being incorporated as well. I will be building it to run in what I believe will be F-mod in the BMWCCA. After some extensive floor rot repair I am assembling the motor and after veiwing this site for only a short time I have found it quite informative. Lots of little bits of info and link to technical data.
BTW. m42 parts are sooo inexpensive!!
I love it!
well most of them...
Ok, back to the business at hand.
The car has a pretty descent cage. Fiberglass m3 wide body fender and not a whole lot else at this point! More to come.
I am just introducing myself and looking forward to catching more information as it comes along on this site.
I plan on keeping the build very inexpensive as funds are quite low. Probably lower than they should be!
I have a well built head with valve work, upgraded springs, cams, porting and a new ecu with a tuned upgrade chip. I think I have 24# injectors for it as well?? So the top end is in wonderful condition. I would like "COP". I can easily get my hands on the coils I just need to fab up the adapter.
As for the lower end... A rod bearing failed and caused the crank to weld itself to the rod. I have another complete engine for doner parts. Excellent block and crank! Probably used only a few times before he overheated it and gave up on the project. I do not need the head at this point so I am not to concerned about it's condition.
I have a couple sets of super sprint headers to use and pending sound restrictions at certain tracks I would like as little exhaust as possible, while still keeping backpressure to the motor. Hopefully side exit exhaust. If I can get a fuel cell to mount in the trunk for cheap. We'll see.
I am going to end up keeping most of the lower end stock as I can not put too much money into it and I can't stroke it because it will bump me up another class. Same for the "FI". So little things are on my list.
Here is my other bavarian princess.
'83 533i body.
euro m30b34 10.5 CR.
euro bumber and headlights.
tons of ungraded susp. components as well as other misc pieces.
Here is the imposter!!
My other car on the track in Canada :D
Cheers;)
« Last Edit: July 07, 2008, 01:39:17 PM by HMS_Tim »
HMS_Tim
m42 track build
« Reply #1 on: June 30, 2008, 01:34:08 PM »
So here is a little update as so where I stand.  I am waiting for a few gaskets and piston rings and hopefully everything will be back together this week.;)
I hate to admit it, but I had to put a little silver on the block.  I had no idea it was almost chrome!
Everything is laid out and ready for final cleaning and assembly.
And I wonder why I broke the two threaded ears on the water pump getting it out!:confused:
More to come in the next week!
« Last Edit: July 07, 2008, 03:05:31 PM by HMS_Tim »
EN318isPDX
m42 track build
« Reply #2 on: June 30, 2008, 02:28:50 PM »
very nice! all those internals look clean! ive been debating to myself if i should buy a new factory manifold and have someone ceramic coat it
HMS_Tim
m42 track build
« Reply #3 on: June 30, 2008, 02:46:45 PM »
Quote from: EN318isPDX;52314
If you really want to coat it right check out the Thermal Dispercent Coating on this site.
http://www.performancecoatings.com
It's pretty pricey, but it makes a significant difference on intake air temps.
They look descent too.  They clean up the parts quite well before coating, so you may not need to purchase a new manifold.  It's worth a call.
« Last Edit: June 30, 2008, 02:49:33 PM by HMS_Tim »
HMS_Tim
m42 track build
« Reply #4 on: June 30, 2008, 03:00:22 PM »
Ok,  I'm just layin some more photos out there for veiwing pleasure.
I was fortunate to get this car already caged.  I am happy with the fact that it was well built.  I still have to gusset a few parts of the cage to the body, but it was a great help having this already taken care of.
The floor is not perfect, but it is now stronger than before and I don't have to Fred Flinstone it any more!
« Last Edit: July 07, 2008, 03:06:04 PM by HMS_Tim »
batsbats
m42 track build
« Reply #5 on: July 01, 2008, 10:38:43 AM »
GL on your build, continue to update the thread!
suvi123
m42 track build
« Reply #6 on: July 01, 2008, 03:26:54 PM »
Looks like fun build, but sad that the body scelecton is so rottend..lot's of late night hours on welding it. But hope that you end up whit a solid car, i'm sure you will. This cage is awsome, and front strut too...
What spring, cams and valves are you using?
Good luck.
318kid
m42 track build
« Reply #7 on: July 01, 2008, 03:42:51 PM »
Wow this is going to be an awesome car! What plans do you have on the motor for the bottom end? Just stock? Also what are you going to do suspension wise? Any direction you go this is going to be a killer project. Good Luck with it.
HMS_Tim
m42 track build
« Reply #8 on: July 02, 2008, 08:15:01 AM »
Quote from: suvi123;52375
Good luck.
The cams are stock out of a newer model,  new retainers, new valves, valve job, decked and ported.  Everything is in somewhat stock form.  Everthing is also going to be polished.
I would invest more money and time if I had both.  Low budget and an event august 8th.  This is the first time I've built one of these bad boys.  I am learning there is alot of little tricks that make a difference.  Maybe if I do this again I will do it up a crazier!
« Last Edit: July 07, 2008, 03:06:35 PM by HMS_Tim »
HMS_Tim
m42 track build
« Reply #9 on: July 02, 2008, 08:46:10 AM »
Quote from: 318kid;52377
The lower end is basically stock.  The pistons have been lightened and balanced.  Polished parts again.  Crank scraper once I get the chance to fab one up.
Suspension...
i had bilstein coilovers for the front.  It is getting converted to an e36 subframe and components.  The rear will be e30 m3 setup.  no coilovers in the rear, but will have adjustable ride height.  Adjusters from an e36 rear control arm I will have to do some tricky fab work for this one.  The rear trailing arms have been braced and have sweet bushings!  Well built rear sub section.  I don't have sways yet.  I don't know how I am going to set these up yet.
HMS_Tim
m42 track build
« Reply #10 on: July 02, 2008, 08:50:44 AM »
So ups just dropped of the new clutch and lightweight flywheel.
15lbs flywheel
I decided to stay with the chromoly flywheel strickly because of the high cost of aluminum.  I wish the clutch was lighter, but oh well...  At least it will eventually wear out!
HMS_Tim
m42 track build
« Reply #11 on: July 07, 2008, 02:04:09 PM »
So this last weekend with the holiday didn't produce alot of extra time for me to work on the motor.  I was only able to work on sunday.  I couldn't build the motor during the week as I was waiting for piston rings that I received on Thursday.  So here is where I am right now.
I will be purchasing an e30 with a guy i work with who wants the motor and such.  I will try to get as much hardware as I can to complete my incomplete body.
Just picked up m3 front fenders and a carbon fiber hood last thursday.  It needs a little bit of repair, but it is pretty light!!:cool:
Everything is in used/crashed condition, so I have some repair work to do
This guy on the hood is my savior!!  Phil Sansassio!!
And the saga continues:rolleyes::D
kenika65
m42 track build
« Reply #12 on: July 07, 2008, 09:05:52 PM »
Damn I love old parts keep this bucket of bolts turnin, its guna be sweet. You have hopefully read this thread the get you more familiar with the m42,
http://www.m42club.com/forums/showthread.php?t=5999
http://www.m42club.com/forums/showthread.php?t=5995
HMS_Tim
m42 track build
« Reply #13 on: July 08, 2008, 12:02:57 PM »
Quote from: kenika65;52880
I have read these threads.  I just read through them again for fun.
There is a wealth of knowledge here and I appreciate everyones input.  This is a first build for me so I am learnig as I go!  :)
HMS_Tim
m42 track build
« Reply #14 on: July 09, 2008, 09:10:52 AM »
I picked up a doner car cheap for all the parts I am going to need to complete the build.  SWEET!!  It's kindof a shame that I am stripping this down the car is in pretty good shape.
Parts of this car will be available for sale in the next several weeks.
I also received the rebuilt shocks and struts yesterday.  I can't wait to start on the body and suspension now!
