Author Topic: m42 track build  (Read 26104 times)
HMS_Tim
m42 track build
« Reply #15 on: July 15, 2008, 07:53:59 AM »
Thought this was pretty funny.
http://youtube.com/watch?v=jbn2OJhp4m8
More to come on the build soon.
HMS_Tim
m42 track build
« Reply #16 on: July 28, 2008, 09:34:00 AM »
I has been a while and I felt it was time to update.
Replaced rear wheel bearings.
I tried to install the motor and realized that the e36 pan and subframe pushed the motor too far back and I didn't have enought time to reconstruct the firewall.
I did some bracing on the cage also.
HMS_Tim
m42 track build
« Reply #17 on: July 28, 2008, 09:55:22 AM »
Since then I have done many other things.
I have got most of the body hung.  The bumper is still just hanging there for the photo.
Here is the dash installed and trim panels made.
I braced the front motor mounts and swaybar mounts.
I made braced rear swaybar mounts.
Repaired the hood
Got the front brakes on minus the brake lines.
EN318isPDX
m42 track build
« Reply #18 on: July 28, 2008, 10:47:53 AM »
Man i bet you are dying to get out and finish up this project! I can't wait to see the final product.. Everytime i see your red sesky cage i get jealous.
HMS_Tim
m42 track build
« Reply #19 on: July 28, 2008, 01:12:37 PM »
Quote from: EN318isPDX;53905
I AM dying to get it done!  It won't look perfect for this year.  I will just rattle can the non red parts for now so it isn't too much of an eyesore.  You know rustolium brilliandrot!  All the final finish on the body work and flat black paint will come over the winter.  It should look SICK once finally painted.
I love the cage too!  If it weren't for it I never would have built this perticular car.  The cage made it worth it.
HMS_Tim
m42 track build
« Reply #20 on: August 01, 2008, 08:41:37 PM »
Well it runs.
Check out the video.
http://www.youtube.com/user/hmsmotorsport
Hodge
m42 track build
« Reply #21 on: August 01, 2008, 09:12:54 PM »
Nice project!
1995 E36 318isc
HMS_Tim
m42 track build
« Reply #22 on: August 05, 2008, 02:11:02 PM »
It runs and drives now.  More pictures once I take some.
Cheers.
tim_s
m42 track build
« Reply #23 on: August 05, 2008, 04:13:53 PM »
wow, great project! What happened with the e36 subframe in the end? did the engine fit in the position further back in the bay? what other problems did you come across? box? linkage? exhaust?
2.1 200bhp, 175ft/lbs 318is
E46 330ci daily
HMS_Tim
m42 track build
« Reply #24 on: August 13, 2008, 08:23:13 AM »
Finally made it!
It is still in process, but it runs and drives very well.
More to come over the rest of the season and winter.
I hate the look of the wing, but I needed the down force, it only weighs 6 lbs and it was already on the car.
Cheers till later guys.
e30guydownunder
m42 track build
« Reply #25 on: September 05, 2008, 05:40:38 AM »
Id like to know about the e36 subframe too. Did it just bolt straight in? Moving the engine back might be a good thing for me, I'll be building a race car very shortly too :)
HMS_Tim
m42 track build
« Reply #26 on: September 08, 2008, 07:59:36 AM »
Quote from: e30guydownunder;56086
I just replied to your pm.
Let me know if it helps out
Cheers,
Tim
tim_s
m42 track build
« Reply #27 on: September 08, 2008, 08:41:26 AM »
any chance of posting up the info publicly? is intriguing.
thanks
tim
E46 330ci daily
HMS_Tim
m42 track build
« Reply #28 on: September 08, 2008, 02:02:46 PM »
Re: Your race car build
Quote:
Originally Posted by e30guydownunder
Hey Tim?,
I saw your thread and want to know more about the
e36 subframe swap.
You say it mounted the engine further back? How much did it interfere with the firewall by?
With the e36 subframe swapped in, did you need the 97+ M3 aluminium lower control arms in order to get the correct caster?
Sorry for all the questions, im about to embark on a similar build (from scratch) myself and knowing things like a factory avaliable subfraqme can be used to mount the engine further back are useful things to know.
Chris
Chris,
Don't worry about the questions. No big deal I hope I can help.
There were several things about the swap that were different. To use the e36 subframe you have to use e36 rubber and engine mounts as the mounting position is wider than the e30. The oil pan and exhaust manifold has to be e36 too. I do not know if the exhaust manifold and down tube will fit once the motor is mounted as I never got it that far in. In addition to that the engine will protrude the fire wall by about 8 inches. You would have to cut a large opening in the firewall to make it fit. you would also have to take into consideration custom driveshaft length, tranny mounts, custom exhaust and shift linkage. I do not know if there is anything that will directly make this fit. I beleive it will be alot of custom work. I might attempt it in the future when I have more time. I am painting the car right now and trying to completely rebuild the brake system with a proportioning valve, all new brake line and abs controller box delete.
I beleive the e36 and e30 have the same lower control arms and the same mounting position on the subframe. They also have the same power steering rack position, but you can't use the e30 rack in the e36 subframe as it's a little bit to tall to fit in between the mounts. I went with a different positioned lollipop mount in the rear of the lowers to get more caster. I also went with e36 m3 front coilovers and spindles and brakes from an e36 325 for the 5 lug conversion. I am running the e30 front sway bay, but decided to use the e36 sway mounts that attach to the strut to reduce stress on the lower control arm as they are used and aluminum. I have steel arms for a back up but am not happy about how much they weigh. I am not sure about how caster and camber differ from e36 to e30 as I have changed so many things on the front end. I am still waiting to complete the car with lexan so I can weigh it and corner balance it. Then I can do an alignment.
I hope this helps you out a little. Let me know if you need anything else.
e30guydownunder
m42 track build
« Reply #29 on: September 08, 2008, 04:26:18 PM »
it helped :)
