There should be 5 hoses, I think. The really small one goes on the small side-nipple on the TB (for the fuel pressure regulator). The bigger air hose on the top-left-front cones from the charcoal canister. The really big air line on the bottom has a 90-degree elbow piece coming right off of it.
The 2 tricky ones are the bottom coolant lines. There should only be one way to fit them on, although it honestly wouldn't matter if you did somehow reverse them. Reattaching them requires you to seat the de-icing part (thinner back plate part) and install the hose clamp with a small ratchet. Then carefully wiggle the rest of the TB in place and get the hose on, and tighten it with a screwdriver or ratchet, space permitting.
