Author Topic: Will 16x7 offset: 28 fit on a 91 318is??  (Read 4124 times)
AlpineRob
« on: May 21, 2008, 07:07:34 PM »
Looking to see if these will fit without any rubbing or problems. Thanks!
AlpineRob
« Reply #1 on: May 21, 2008, 07:11:46 PM »
ALSO! would anyone be able to tell me about how a 28 offset would sit in the wheel well?? would it be flush with the fenders or would it stick out..? i have no knowledge of offsets as you can tell. thanks everyone
BrandC
« Reply #2 on: May 21, 2008, 08:55:46 PM »
16x7 +28mm offset wheels will fit just fine in our cars. However, the wheel will be very sunken inward, almost identical to stock.
AlpineRob
« Reply #3 on: May 21, 2008, 09:21:03 PM »
Do you think it would look alright or awkward..?
BrandC
« Reply #4 on: May 22, 2008, 11:41:46 AM »
It all really depends on what look you are going for, and also what suspension setup you are running. If you have a drop anywhere from 1-3", I think the wheels will look awkward with the camber/toe change.
I suggest you look for a set of lower offset wheels, something between +10-25mm, 7-8" wide.
AlpineRob
« Reply #5 on: May 22, 2008, 05:45:46 PM »
how about using a spacer to bring the wheels flush with the fenders?
BrandC
« Reply #6 on: May 23, 2008, 12:33:50 PM »
Quote from: AlpineRob;49908
If it's ET +28mm, then you are going to need at least 25+mm spacers, front and back. That's going to look terrible too.
