Author Topic: help please!  (Read 3720 times)
B318M42W
help please!
« on: May 08, 2008, 09:09:45 AM »
Hey guys...
running problems again and I'm not quite sure what it is this time... what do you think???
Here are the symptoms:
-lack of power
-when started hot, the engine seems to not take any rpm change ie: give gas to 1500rpm, and it goes back down to 1000. try driving with it and it almost stalls. condition lasts for about 1 minute. If i give it a few short taps on the gas (3500-4000 rpm) it shortens the time laps. It started doing this when i shecked the O2 sensor if it was still good (still works, but could be better)
- exaust smells strong
It doesn't burn any oil, but i do get a bit of coolant in the oil... did compression test 215-225 psi on all 4. not sure if i did it right ( I cranked until the gauge stopped rising, about 4 turns)
any help greatly appreciated!
M90 Blown M42 :cool:
ScreamerBeemer
help please!
« Reply #1 on: May 09, 2008, 09:56:23 PM »
What about when started cold?
nuvolarossa
help please!
« Reply #2 on: May 10, 2008, 03:10:59 AM »
but is the car shaking/engine a lot or it has irregular erogation?
how is coolant level in reservoir?
help please!
« Reply #3 on: May 10, 2008, 08:08:50 AM »
do you have a good spark?
check your fuel pressure
check if your AFM flap is working
check your throttle position sensor
what happens when the engine is cold?
B318M42W
help please!
« Reply #4 on: May 10, 2008, 01:24:49 PM »
I do have a good spark and it runs smooth and all... even when hot. the problem is only during the first minute or so when it's hot.
I've worked on it since i posted, and now it's completely gone wild... here's the work i did:
changed MAF, changed cat conv.
now it won't start at all... the fuel pump isn't working. and it's barely 6 months old. I checked the fuel pump relay (replaced it with fog light relay to test) and it's still good. checked the cam/crank sensor wires, ok. checked for spark, have good spark.
don't knopw where else to look...
thanks for any help!
RED IS 91
help please!
« Reply #5 on: May 10, 2008, 04:08:43 PM »
How did you check the cam crank sensors ???
B318M42W
help please!
« Reply #6 on: May 10, 2008, 05:44:54 PM »
i simply checked if the wires/connections were loose
RED IS 91
help please!
« Reply #7 on: May 10, 2008, 06:50:39 PM »
are you getting any codes back?
B318M42W
help please!
« Reply #8 on: May 10, 2008, 09:22:38 PM »
Only code that i get is 1444  (no code stored)
B318M42W
help please!
« Reply #9 on: May 10, 2008, 10:33:52 PM »
got it! it works now:D The fuel pump connector ( C190) was "loose"... the wires that go into the connector weren't doing a good contact, thus not providing the power to the fuel pump! thanks for all your help!
nuvolarossa
help please!
« Reply #10 on: May 11, 2008, 05:39:03 AM »
now go and enjoy it :)
B318M42W
help please!
« Reply #11 on: May 11, 2008, 10:33:14 AM »
over and over and over again!
