Author Topic: E30 M3 springs? Where to get? Only used?  (Read 3427 times)
nomad
« on: May 05, 2008, 10:46:32 PM »
So I read that these are a slightly stiffer than the stock 318iS springs? True?
Lower the car .25"? True?
If so then I'm thinking that may be a cost effective solution combined with spring pad removal. Maybe it'll tide me over till I can get some H&R sport or race with Billys or Konis.
For now i'm in super tight budget mode and trying to get parts for suspension and brakes.
SoCal, 318is: IT RUNS AGAIN!
« Reply #1 on: May 06, 2008, 04:54:36 AM »
hmm.... i know where a douzen or more complete m3 suspensions are... but shipping to the us?!
monty23psk
  • -Receive: 17
« Reply #2 on: May 06, 2008, 08:56:37 AM »
check s14.net. I saw someone selling some springs. not sure if it was all 4 or just the rear.
nomad
« Reply #3 on: May 06, 2008, 10:59:24 AM »
Just read from B Purcell that the M3 springs are nearly identical to the 318iS springs with the rear being only slightly stiffer. Not worth it as most people want about $100 for them.
Just thought I'd share.
I'll look for aftermarket.
tony92ic
« Reply #4 on: May 06, 2008, 12:32:32 PM »
I've got M3 springs on my 318ic and they are definately stiffer and slightly shorter than the OEM springs. I removed the spring pads as well and its really a nice ride height for a daily driver. Handles 100% better than oem. Decent ride quality. With an ic I was worried about it becoming too stiff. I would do this again on a street car versus aftermarket springs. If i was autocrossing it would be a different story.
Unless the is springs are stiffer than the ic springs i don't think they are "nearly identical" at all.
I put eibach road race (NLA) springs on the M3. That along with delrin and urethane bushings is rock hard. I can tell the difference between a dime and a nickle at 30 mph.
Tony
92 e30 318ic - Why I am here
72 2002tii - Much modified
91 M42 - Am I a hoarder?
nomad
« Reply #5 on: May 06, 2008, 01:13:10 PM »
Ok, maybe the info is wrong then. Post pics please!
I know the vert is little heavier than the coupe but I was hoping to remove spring pads too.  I've got the 4x4 stance right now but I want any additional performance benefit of stiffer springs too.
