im in the middle of building my m42. lets get to the point...
my goal is 300 - 350 RHWP.
what im getting
-CP forged pistons (9:1)oversized to 86mm(stock is 85mm) from vacmotorsports
-MLS headgasket (.060 - .080) depends on if and how much my head has to be milled down
-ARP headstuds
-performance / racecoated rod bearings
-machine shop work, already did my home work and got some prices, found a local shop that does awsome work, definetly got good references. boring my block to match the pistons(86mm = 2.0L?) balancing and polishing my crank, shotpeen my stock rods, mill my head(if needed) and 5 angle valve job ALL for $430
-Metric mechanic turbo cams/beehive springs/titanium keepers. ive already port/polished my head
im just doing the build first, getting the megasquirt straight and get it running good. hopefully will be boosted by fall. then we'll worry about the turbo/fueling/exhaust... And of course im doing all the other things like waterpump/Tchain/all other gaskets and seals/and sensors. and i have already purchased a COP kit from rob on here.
thoughts....? comments.....?
