E36 serpentine accessory problem>????
Author Topic: E36 serpentine accessory problem>????  (Read 3854 times)
Artem
« on: April 19, 2008, 02:26:58 AM »
Hey guys, I just tried to finalize my motor today and I stumbled into one hell of a problem - the oil dipstick is not cooperating if I use a serpentine belt.
Did anyone come up with a way to solve that problem?
-Thank you all, Artem
________________________
Artem Lepilov
WPI Aerospace Engineering
Class of 2008
hesgone2fast
« Reply #1 on: April 19, 2008, 05:18:37 AM »
I have converted mine to serpentine belt.
to clear the dipstick, you have to make it go between the crank pulley and the power steering pump, you will have to bend it in an "S" shape to make it go up again. and secure it with a clamp to one of the bolts down there(I think the tensioner or something around there).This makes it a little harder to pull the dipstick, but it´s ok.
 I can post a pic or two if you want.
Artem
« Reply #2 on: April 19, 2008, 02:27:17 PM »
Damn, yea - can you please post a pic. I tried to do that, but I rushed it and ruined my dipstick. I should have a spare somewhere.
-Thank you very much!
 Artem.
Artem Lepilov
Class of 2008
HaNasich
  • OO==00==OO
    • http://www.bangbros.com
« Reply #3 on: April 19, 2008, 05:54:23 PM »
man
this is such a shit-place to go with the dipstick - but there's no other option.
i had so much shit with this.
than i had to modify the dipstick itself as well.....
WowMom
BTRA!
Artem
« Reply #4 on: April 25, 2008, 01:35:51 AM »
Here are some pics of mine. I have no idea why i cant post up any pics - it fails me every time...
In any case, I will add the top of the dipstick tube to the hose and extend it exact amount needed for the dipstick to be touching the oil and then I will take it from there. It seems to be sealed up otherwise.
Also, I took apart my old motor and it looks damn good, valves are all straight, block crosshatch is better than that on my newer motor :confused: I have no idea why as that motor has 78k miles on it, and my old one had that plus 100k.
-Artem
Artem Lepilov
Class of 2008
nickmpower
« Reply #5 on: August 24, 2008, 09:53:01 PM »
has anyone found any other solutions to this?
hesgone2fast
« Reply #6 on: August 25, 2008, 03:41:22 AM »
Hey guys, here´s a pic of my solution to the dipstick deal, it´s been bent in an "S" shape, and bolted to one of the power steering pump bolts with a clamp.
It has enough clearance all around, it is a little harder to pull out, but the reading is accurate.
nickmpower
« Reply #7 on: August 29, 2008, 01:34:13 PM »
fuck i think i might be screwed. Im going to pick my 95 engine up today, and i am not going to use power steering.
kenika65
« Reply #8 on: August 29, 2008, 01:46:06 PM »
Um why cant you just use all e36 parts? Idk so sorry for dumb question.
Cant you use every thing off of an e36 and still have ac and everything?
nickmpower
« Reply #9 on: August 29, 2008, 05:12:46 PM »
the oil pan doesnt clear the e30 subframe
hesgone2fast
« Reply #10 on: September 02, 2008, 02:20:21 AM »
Quote from: wajiguqu0223;55860
The afoot output of Korean-developed MMORPG titles suchlike Fantasy of Mirror Online, FlyFF and Rappelz are eve isk experience relics of a experiencelank forgotten. This is the condition braving Aion:The Shape of Existence, the current from the archetype Altaic MMOG creators at NCsoft.
Can someone please kick this guy out of the forum?
Thanks!
Cobra Jet
« Reply #11 on: January 12, 2009, 12:01:06 PM »
was there ever any resolution to getting the oil disptick & tube assembly fitting any better after performing a serpentine conversion?
Also, are there any better pictures of the front of an M42 after the serpentine conversion has been completed?  I've been trying to look for something online to see the entire pulley/accessory system layout, but have had no such luck finding a good image or pic....
- Phil
1994 Cobra coupe #0013
2011 Genesis Coupe
2011 Tucson GLS
JP 91iS
« Reply #12 on: January 13, 2009, 11:21:18 PM »
Check the PDF in this thread.
They've got a good picture on the 3rd page.  They said they only had to bend it over about 10 degrees -  but might be different if you don't have the supercharger.  Good tip they throw in is to bend the dipstick tube in a vice with a rod inside the tube to keep it from pinching.
-JP
Project M42: generating funds
