Author Topic: small mod with two washers :)  (Read 5026 times)
romkasponka
« on: March 30, 2008, 08:58:44 AM »
After one bmw 318is owner in Lithuania tested (~1000km) this simple mod I tried it on my own M42. Two washers ~1mm thick each was installed between plug and hydraulic chain tensioner. Result: chain rattle disappeared in 2500-3000rpm band. :cool:
p.s. My engine block was shaved 0,9mm for 11:1 compresion ratio.
E30 318is M42
E36 318is M44
318is93
« Reply #1 on: March 30, 2008, 10:29:47 PM »
This on a new or used tensioner piston?
romkasponka
« Reply #2 on: March 31, 2008, 01:50:11 AM »
Quote from: 318is93;45800
This is on used ~20kkm tensioner.
Unfortunatly second impresion was not so good (first attempt was with cold engine), but it works.
E30 318is M42
E36 318is M44
« Reply #3 on: March 31, 2008, 11:59:36 AM »
Do the washers go between the tensioner and the threaded plug that goes in behind it. I have thought about a mechanical version of the tensioner with an adjustment for the pressure as an alternative to the oil pressure/spring type that is OEM. Also with the tension applied by a toothed gear wheel instead of a guide rail. Timing belt cars use this approach with the external belt.
318is93
« Reply #4 on: March 31, 2008, 02:44:16 PM »
How hard would that be to come up with something like that?
romkasponka
« Reply #5 on: March 31, 2008, 03:10:22 PM »
Quote from: D. Clay;45816
Yes..
E30 318is M42
E36 318is M44
Marcp
« Reply #6 on: December 17, 2008, 06:33:28 PM »
Anymore thoughts on this?   Fed up with the 3000rpm rattle I have...
roundel318
« Reply #7 on: December 17, 2008, 10:31:03 PM »
Got a soundclip?
Marcp
« Reply #8 on: December 18, 2008, 07:11:42 PM »
Dont want to try this at the weekend and then find it snaps the chain lol!
batsbats
« Reply #9 on: December 18, 2008, 07:58:49 PM »
the heck? interesting.
Jimmy Lewis
Ead
« Reply #10 on: December 19, 2008, 08:07:53 PM »
Eat a dick spam bot, kthx.
1999 Estoril M3
1991 Brilliantrot 318iS
(for sale)
Marcp
« Reply #11 on: December 21, 2008, 06:08:05 PM »
Tried this at the weekend, just one 1mm washer for now.
It worked! Sort of... still a little rattle at 3700rpm-4000rpm.
Then I drained the oil and found big end bearing peices.
DEEP JOY :)
Deftones
« Reply #12 on: December 22, 2008, 02:37:41 PM »
why did you do this? wasn't it simpler changing the chain tensioner? i've done it on my 318is and it works well!
http://blogs.yahoo.co.jp/luca318is
1992 318is e36
1990 318is e30
TheDutch
« Reply #13 on: February 15, 2009, 10:28:41 AM »
Any more updates on whether this is a good idea or not?! Seems like it could be asking for trouble.
JoeDellio
« Reply #14 on: February 18, 2009, 09:22:07 PM »
I dont see how this would work. The spring inside is just gonna soak up the extra tension from the washers. I dont think it would be 100% transfered to the chain. I think this is just asking for premature tensioner failure. Any one else with me?
[SIGPIC][/SIGPIC]1995 318i
