Author Topic: What is a hardy disc or joint disc  (Read 3365 times)
Zilla
« on: March 25, 2008, 03:38:03 PM »
Excuse my ignorance, I searched the site and and found nothing to this name, also check out oemparts.   Any ideas, of what its purpose is, thanks.
-E
« Last Edit: March 25, 2008, 03:43:35 PM by Zilla »
ten2doyle102
« Reply #1 on: March 25, 2008, 05:49:26 PM »
i believe that it the coupling between the transmission output shaft and the driveshaft.  there shoud be 6 bolts going through it.
oldtimer
« Reply #2 on: March 26, 2008, 07:17:34 AM »
http://www.realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=26_0009&hg=26&fg=10
If you are talking about Item 2 that's the thick rubber mounted between the transmission outfut flange and the drive shaft.  it acts a vibration absorber.
Wise Old Dog
« Reply #3 on: March 26, 2008, 07:35:36 AM »
Guibo?
« Reply #4 on: March 26, 2008, 08:12:12 AM »
yes, on the link above the number 2 is called a hardy-disc.. joint-disc is a similar word
« Last Edit: March 26, 2008, 08:16:25 AM by swiss318is »
Zilla
« Reply #5 on: March 29, 2008, 09:13:28 AM »
Sweet i think thats what it is, because the mechanic i had taken it to told me that there was a vibration in the car due to that, is it hard to change for someone who doesn't have a garage, or access to a lift?
Wise Old Dog
« Reply #6 on: March 29, 2008, 10:00:58 AM »
That is a Guibo. You have to drop the exhaust, underbody shield or panel. 6 bolts. You need a 17mm 6-point box end wrench. Use all new lock nuts, and make sure the arrow on the side of the guibo is pointing fwd. Tighten your bolts evenly, progressively,  and in a cross pattern.
If you don't get it right, you'll be doing it again. It will vibrate itself to pieces. I know from experience.
It can be done without a lift.
FCP Groton has a good price , so does a vendor on e-bay called joeltec (sp?)
Now is a good time to replace your center support bearing if it hasn't already been done.
beegeezy
« Reply #7 on: March 29, 2008, 11:44:39 AM »
Ohh, I wasnt sure what he was talking about before. Never heard it called a "hardy" disc before. Usually called a guibo or flex disc.
It\'s not paranoia if they really are out to get you.
