Measure value off a sensor camshaft
Author Topic: Measure value off a sensor camshaft  (Read 2290 times)
Fab318IS
« on: March 19, 2008, 11:31:28 PM »
Hello everybody,
I am Fabrice, i live from Belgium , i posses a bmw E30 - 318IS
I like this car ! :) (i don't find the presentation thred but i speak a little english ;) )
I need your help for this next problem :
I have a question on sensor camshaft, the piece is registred as a number 6 :
http://bmwfans.info/original/E30/2-T/318is-M42/ECE/L/M/1990/03/mg-11/ill-11_2683/
How much does the resistance measure ?
I have measured and i find 1567 ohm.
i have measured between borne 1 and borne 2 with the multimeter
Can you help me pease?
Thank you very much
Fabrice
RED IS 91
« Reply #1 on: March 20, 2008, 04:00:44 PM »
Welcome to the M42club.
It should be 1280 + or -  10 %
good luck
Fab318IS
« Reply #2 on: March 21, 2008, 01:16:46 AM »
Hello,
Thank you for your reply.
Do you know the value of resistance of the sensor pulse?
Piece n°12  http://bmwfans.info/original/E30/2-T/318is-M42/ECE/L/M/1990/03/mg-11/ill-11_0156/
Me I measure 568 ohm
568 ohm for sensor pulse and 1568 ohm for sensor camshaft,
It should not have the same measure ????
Thank you
Fabrice
RED IS 91
« Reply #3 on: March 21, 2008, 04:10:42 AM »
It should be around 550-560 ohms for the crankshaft position sensor which is number 12 in you picture. It sounds like your camshaft and crankshaft position sensors are good .
