DISCUSSION
Engine + Driveline
LSD Rebuilding
Topic: LSD Rebuilding (Read 4472 times)
Paul Strefling
LSD Rebuilding
March 16, 2008, 12:46:10 PM »
Are there any kits for the small case LSDs, such as this one from bimmerword?
http://store.bimmerworld.com/shared/StoreFront/default.asp?CS=bimmerworl&StoreType=BtoC&Count1=981228053&Count2=898368477&Keyword=lsd&Target=products.asp
Thanks
Hero Member
LSD Rebuilding
March 16, 2008, 02:29:48 PM »
sorry but the link doesn't work
Legendary
LSD Rebuilding
March 16, 2008, 03:18:03 PM »
The link just goes to the storefront. Are you trying to put in new seals/bearings or are you trying to change out the ratio?
Paul Strefling
LSD Rebuilding
March 16, 2008, 04:04:24 PM »
This link should do the trick:
http://store.bimmerworld.com/shared/StoreFront/product_detail.asp?RowID=584&CS=bimmerworl&All=
I am actually looking to replace all wear components in the diff, bearings, clutches, etc. I actually still need to locate one...
Hero Member
-Receive: 1
LSD Rebuilding
March 16, 2008, 04:16:44 PM »
yes.. keep on posting, i need some help.. i am rebuilding a m3 diff and a gearbox...!
1991318is
Global Moderator
Sr. Member
LSD Rebuilding
Reply #5 on:
March 17, 2008, 05:36:23 PM »
The clutches I don't think I've ever seen those for the e30 diff's. Don't even think I've seen a rebuild kit for the small case either.
Paul Strefling
LSD Rebuilding
Reply #6 on:
March 17, 2008, 05:44:29 PM »
Here is a link to a tear down of what I believe is a medium case LSD:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=296-13633-5-ND
If there is no rebuild kit for the small case LSD then I assume I should install the medium case.
Legendary
LSD Rebuilding
Reply #7 on:
March 18, 2008, 01:47:11 PM »
If you can find a reasonably priced med. case 4.10, go for it. They are pretty tough to find, though. Try calling BMA (BMAparts.com). They seem to be able to find anything.
DISCUSSION
Engine + Driveline
LSD Rebuilding
