Author Topic: Startup not as responsive  (Read 2262 times)
n2motorsports
« on: March 13, 2008, 04:44:23 PM »
Car use to start right up upon turning the key, now it'll do the "i dont' wanna go to school today" whine. In other words, takes about 2-3 seconds to start. Any ideas what's going bad, maybe the starter, injectors, coils (i bet they are all original). I've already replace plugs in Dec 07.
Course why fix it unless it's broke, but it's probably a good time to hoard some parts in the events it does break sooner or later. Thanks.
Vladi
    • http://www.bmwzone.ro/forum
« Reply #1 on: March 13, 2008, 05:25:20 PM »
A friend has the same problem...Checked everything...:confused:
Jak318
« Reply #2 on: March 13, 2008, 08:45:29 PM »
Didn't someone have this problem and ended up fixing it by putting a check valve in their fuel line?
beegeezy
« Reply #3 on: March 14, 2008, 12:35:39 AM »
Yes, he(forgot who it was, he posted it up on the 'tech too), found that his fuel was running from his lines back into the tank while the engine was off. He installed a check valve, and no more problem.
