Author Topic: Let's see some aftermarket gauge installs  (Read 32931 times)
Cobra Jet
« on: March 08, 2008, 12:04:05 PM »
Have any of you installed any aftermarket VDO gauges?  If so, did you use an aftermarket gauge panel or create one yourself?  Where did you chose to install it?
Are you using any mechanical gauges or all electric?
How did you go about routing any of the wiring or if mechanical Stainless Steel braided lines?
I've seen some aftermarket panels available for the E30's, but am not too overly thrilled with the design or placement (it seems they usually get installed "behind" the shifter under the HVAC control head).
Post 'em up fellas!
- Phil
1994 Cobra coupe #0013
2011 Genesis Coupe
2011 Tucson GLS
« Reply #1 on: March 08, 2008, 01:50:31 PM »
Say what you will about the ricer look, I honestly prefer my gauges where I can see them without taking my eyes off the road, and since I use my AC occasionally:
This is the Lotek gauge pod for the M3, picked it up several years ago. Only fitment issue is at the very top, it doesn't quite match the contour of the original:
It's close enough that it's not all that noticable unless you are looking for it.
« Reply #2 on: March 08, 2008, 11:20:17 PM »
Wow that looks good!
I have an ashtray pod that will accept three gauges, but now that I look at the pillar pod, I'm really digging it.
How much did it cost ya?
« Reply #3 on: March 09, 2008, 03:46:00 AM »
I think it was around $40, but again, that was several years ago, and now I can't seem to find one on the 'Net....   I picked mine up on Fleabay.
EDIT:  A-ha!  http://www.gaugepods.com, although the webpage does not seem to be responding.
quinn11m20
« Reply #4 on: March 09, 2008, 07:18:19 AM »
Yeah ! I purchased one of the ashtray pods with the volt, oil pressure and oil temp. Man I must have some electrical problems I can't find. I tried wiring it up about a year ago and with no resolve none of my gauges work. All three gauges peg out as soon as I hook up the positive lead. I have changed all the grounds and just recently replaced the Alternator. It was the original Alt after 232K. I have read the instructions thoroughly, that I got from BMP Design and still can't get any of them to work. HELP! Anyhow, at least they look cool where they are at.
« Reply #5 on: March 09, 2008, 07:24:34 PM »
I'm going to be wiring oil temp and pressure pretty soon; I'm considering drilling holes in the rear center console where the flat area is for the gauges or putting them under the lid of the ashtray (although mine is modified for storage and it is a great place for change and the cig lighter when the Ipod is charging). I don't smoke and never will, but I hate having the emty hole in the dash.
Cobra Jet
« Reply #6 on: March 25, 2008, 08:23:06 AM »
Quote from: quinn11m20;44355
Do you have any links or pics to see this "ash tray pod" style of gauge holder?
As far as the help you need - all of the black wires will be going to a good ground.  Find a good ground within the interior of the car, it has to be cleaned of any painted surface and make sure all of the wires are contacted evenly against the metal when screwing them down to secure them.  As far as your positive leads - depending on which gauges you are running, you will want to find a good fuse in your fuse block to tap into for each functional gauge (ie: volts, lighting, etc).  Again, make sure that each wire is secured properly and is making proper contact.
For instance, for the gauge lights - ground the ground (-) lead.  There should also be a lead (+) that will come off the back of the gauge housing.  Take this lead and tap it into the proper fuse for your interior lighting.  If you have properly tapped into the correct fuse, the gauge lights will only illuminate when you turn on/off your parking lights, will also work when turning on/off all lights and they will also "dim" when using the dimming function.
Now for volts gauge, you need to tap the positive lead (+) into either a fuse or wire harness that will get power once the ignition will be turned on w/ engine running (KOER) and of course you ground the black (-) lead again.
Coolant temp, oil temp, oil pressure, trans temp, etc - all of these other gauges should come w/ specific instructions as for tapping the gauge leads into the proper senders for the engine.
- Phil
2011 Genesis Coupe
2011 Tucson GLS
quinn11m20
« Reply #7 on: June 22, 2008, 05:29:48 PM »
Hey thanks for the help. I got the voltmeter and the oil temp working but the oil pressure is not. I think the gauge bmp design sent me was bad. I will change it later for somthing else like eng coolant temp. Thank for all your info.
Lund8200
« Reply #8 on: September 02, 2008, 04:04:49 PM »
Here are some pictures of my gauges in the center consol.
I got oil pressure, oil temperature and air/fuel ratio.
EN318isPDX
« Reply #9 on: September 02, 2008, 04:26:18 PM »
Quote from: Lund8200;55892
DAmnnnnnn I'm jealous!! Where and how much! If thats the bavauto one thats worth 200 to have it look that flush
ose30
« Reply #10 on: September 03, 2008, 04:49:49 AM »
I installed three VDO's on the dashboard. I used BMW factory panel, which was readliy available back in 1989 when i did it! Do not know if this panel is still available.
I just scanned from old Hartge & Schinzer cataloques pictures from where you can see what was available back in 1990.
« Last Edit: September 03, 2008, 04:59:25 AM by ose30 »
EN318isPDX
« Reply #11 on: September 03, 2008, 11:23:20 AM »
Those gauges above the heater vents kinda bothers me but i most defiantly like the other one! I wouldn't know what to do with my change if i had gauges there though
txleadfoot
    • Google Profile
Console Mounted Gauges
« Reply #12 on: September 29, 2008, 11:42:08 AM »
How much clearanced do you have between the front of the console and the heater equipment?  I may install VDO gauges in the same spot with angle dimmer rings pointed at the driver.
Quote from: EN318isPDX;55893
Cobra Jet
« Reply #13 on: September 30, 2008, 10:27:33 AM »
What brand or type of gauges are those and where did you purchase them from?  Are they all electric gauges or are some of them mechanical?
- Phil
2011 Genesis Coupe
2011 Tucson GLS
« Reply #14 on: September 30, 2008, 08:48:51 PM »
ose30, a friend of mine has the gauge housing that mounts on top of the dash over the vents. it actually looks a lot better in real life, although I've never seen that for sale and he isn't interested in selling. ;) He's also got a full ACS kit on the car.
