Author Topic: Adjustable front camber plates  (Read 9976 times)
twism
« Reply #15 on: March 01, 2008, 10:10:23 AM »
You have some interesting pictures in your blog, I can tell in your country roads are pretty similar to mine, because same thing happened to my oil pan but not as bad as yours. The camber plates are really nice. Are they custom made for you or I can order a set :D
romkasponka
« Reply #16 on: March 01, 2008, 11:29:54 AM »
They was designed by me. I think little bit later you can order a set.
I have rears too, but they are not finished yet and not ready to be revealed :D
E30 318is M42
E36 318is M44
DZick
« Reply #17 on: March 01, 2008, 03:51:24 PM »
Vorschlag > all
fabe
« Reply #18 on: March 02, 2008, 02:05:43 AM »
Took some shots just now...
As you can see, I didn't dial in much camber but the front bites well enough even for track days... Tyre wear is pretty even for the front..
Anyway, just sharing.. Don't think it's feasible to ship anything heavy half the globe away... Furthermore, the top nuts are different for different types of shock absorbers... some have 12.5mm thread and some 1.5mm thread..
oh btw, the IS lip you see in the photo is actually beaten out of sheet metal...
« Last Edit: March 02, 2008, 02:14:00 AM by fabe »
romkasponka
« Reply #19 on: March 02, 2008, 02:39:38 AM »
Quote from: fabe;43960
1,25mm and 1,5mm I think..
p.s. dont you think you should add some grease?
« Last Edit: March 02, 2008, 02:51:27 AM by romkasponka »
E30 318is M42
E36 318is M44
twism
« Reply #20 on: March 02, 2008, 12:21:56 PM »
how much of a negative degrese is that, do you know?
fabe
« Reply #21 on: March 02, 2008, 07:17:06 PM »
Quote from: twism;43977
Should be about -1.5 degree...
« Reply #22 on: March 16, 2008, 04:12:39 PM »
adjustables from kw-coilovers from germany.. 800.-$ both, specially made for your car and your coilovers :-)
Letsplayskatch
« Reply #23 on: May 01, 2008, 07:55:12 AM »
^^ Swiss, how did you go about getting those made? Or can you buy them off the shelf? Ive notices there arent that many coilover manufacturers who do decent kits, other than KW.
« Reply #24 on: May 01, 2008, 08:37:30 AM »
well, kw produces this Adjustable front camber plates to fit perfect with your kw coilovers.. i have no idea if it fits with other coilovers.. but i think, when the kw coilovers fits in the stock camber plates the adjustables will simply replace it.. but to be sure i have to ask..
Letsplayskatch
« Reply #25 on: May 01, 2008, 11:31:54 AM »
Well id imagine that their adjustable top mounts are universal, most kits are but correct me if im wrong. Do you have a link for the KW top-mount plates?
« Reply #26 on: May 01, 2008, 01:10:40 PM »
i am sorry but there is no link anywhere for the mounts!! they are racingparts and produced on demand, so you can give them a call and ask and they will start their mills to work only for you..:D
Letsplayskatch
« Reply #27 on: May 02, 2008, 09:53:05 AM »
Ah ok, cheers dude! will have to talk to my dad about that as he knows all the right people for that stuff :D
