Author Topic: problems with thick Headgasket  (Read 3123 times)
WeirdYo2
« on: January 25, 2008, 08:28:30 PM »
Has anyone who ran a thicker headgasket had problems with their profile gasket blowing? ( http://www.realoem.com/bmw/showparts.do?model=AF93&mospid=47305&btnr=11_0156&hg=11&fg=10 ) part number 10... mine failed on the backside of the opening for the thermostat.  Since it is sealed between the head and the cover, if you use a thicker headgasket and raise the head up it might not hold up as well and I completly overlooked this when i put my gasket on.  I havn't been able to find any information on it so I was just wondering what everyone elses experiences were with this.
bar73k
« Reply #1 on: February 22, 2008, 10:28:05 AM »
i completly rebuilt my engine and put a stainless steel headgasket in, ever since i have not been able to stop oil leaking from that area.
i have pulled down the motor a second time to put some silicon there to maybe stop it but recently it started leaking again.
its not a massive leak, just very very annoying since i rebuilt it
stereomotional
« Reply #2 on: February 23, 2008, 02:30:46 PM »
wow thats weird...but good to know since im doing a thicker hg so maybe i can address that problem when i rebuild
mkIV Jolf 1.8t (the DD)
« Reply #3 on: February 23, 2008, 07:17:44 PM »
Sounds like a piece of sheet aluminum cut to fit would do the job. Link to 12" X 12" sheets for $5-$10. I buy little stuff from them, most recently plate for caliper brackets.
http://www.speedymetals.com/c-8373-3003.aspx
