Author Topic: noise when turning left  (Read 3759 times)
gundy318
« on: January 25, 2008, 12:08:03 PM »
My car recently started making a juddering/rattling noise when i make left turns. It seems worse when the car is cold and going at low speeds. It never does it when i turn to the right and it sometimes does it lightly when i'm going straight. It sounds like its coming from the rear end. What's weird is if i'm making a left turn and its making the noise pretty bad and i push the clutch in, the noise fades out. Someone on r3v had a similar problem but he said it just went away on its own. Any ideas?
ethirty
« Reply #1 on: January 25, 2008, 01:31:53 PM »
i had the same thing going on (minus the clutch), and it was the rear wheel bearings.  PITA to do yourself, so i paid 500 to get both done.  grab your wheels and shake em hard to see if you can feel or hear any play.  just an idea.
gundy318
« Reply #2 on: January 25, 2008, 07:53:56 PM »
thanks for the help. i think it might be goin to the shop soon if i can't figure it out.
gundy318
« Reply #3 on: January 28, 2008, 12:56:08 PM »
so it turns out that at some point when i took the car apart and put it back together again i didn't tighten one of the exhaust support things enough and it was rattling against the exhaust during left turns. I feel pretty stupid but i guess i'm lucky thats all it was.
Spec 2
    • http://www.pnwriders.com
« Reply #4 on: January 28, 2008, 06:34:16 PM »
Good to hear it was a simple fix.
