DISCUSSION
Suspension
noise when turning left
Topic: noise when turning left (Read 3754 times)
gundy318
Jr. Member
January 25, 2008, 12:08:03 PM »
My car recently started making a juddering/rattling noise when i make left turns. It seems worse when the car is cold and going at low speeds. It never does it when i turn to the right and it sometimes does it lightly when i'm going straight. It sounds like its coming from the rear end. What's weird is if i'm making a left turn and its making the noise pretty bad and i push the clutch in, the noise fades out. Someone on r3v had a similar problem but he said it just went away on its own. Any ideas?
ethirty
January 25, 2008, 01:31:53 PM »
i had the same thing going on (minus the clutch), and it was the rear wheel bearings. PITA to do yourself, so i paid 500 to get both done. grab your wheels and shake em hard to see if you can feel or hear any play. just an idea.
gundy318
Jr. Member
January 25, 2008, 07:53:56 PM »
thanks for the help. i think it might be goin to the shop soon if i can't figure it out.
gundy318
Jr. Member
January 28, 2008, 12:56:08 PM »
so it turns out that at some point when i took the car apart and put it back together again i didn't tighten one of the exhaust support things enough and it was rattling against the exhaust during left turns. I feel pretty stupid but i guess i'm lucky thats all it was.
Spec 2
Jr. Member
January 28, 2008, 06:34:16 PM »
Good to hear it was a simple fix.
DISCUSSION
Suspension
