Author Topic: Oil pressure gauge  (Read 9853 times)
kowalski
  • El\' Duder
Oil pressure gauge
« on: January 11, 2008, 04:21:45 PM »
Alright people, I'd like to know what my oil pressure is these days, the motors got 320,000 km's on it and still seems to run great. I had a little scare this last week when the oil light came on, but i swapped out the sensor with my buildup motor and the light is off now, so it was just a crapped out sensor.
Regardless, I would like to put in an oil pressure sensor, so does anyone know where i can get the T fitting I need to do so? This motor only has to last another 4-5 months and then it gets retired!
Mike
Sale:
Fore Sale Thread
Oil pressure gauge
« Reply #1 on: January 11, 2008, 04:44:45 PM »
i am also interested in this but have no clue where to start, maybe oil temp would be nice at the same time
kowalski
  • El\' Duder
Oil pressure gauge
« Reply #2 on: January 14, 2008, 01:45:07 PM »
bump?
Sale:
Fore Sale Thread
Wise Old Dog
Oil pressure gauge
« Reply #3 on: January 14, 2008, 03:36:19 PM »
I've seen the small manifold block that goes where the oil pressure switch goes. On the side of the filter housing. Allows 2 lines to be connected. They are sold on e-bay, not expensive. Or you could spend $100 on the filter housing top that is ported for 2 fittings. My son has one, looks good. There is also an oil drain plug that has a hook-up for a temp gauge.
jakeb
Oil pressure gauge
« Reply #4 on: January 14, 2008, 06:09:07 PM »
You can get a sensor that does both.  But you would have to hack into your harness somehow to connect the different sensor to the dash light.
http://www.classicdaily.net - swapping this into that
http://www.blunttech.com - all your parts needs
RED IS 91
Oil pressure gauge
« Reply #5 on: January 14, 2008, 06:45:47 PM »
some good reading and parts here ,,,,,,, read the whole thread
http://www.r3vlimited.com/board/showthread.php?t=96720
kowalski
  • El\' Duder
Oil pressure gauge
« Reply #6 on: January 14, 2008, 07:30:47 PM »
great thanks
Sale:
Fore Sale Thread
Oil pressure gauge
« Reply #7 on: January 15, 2008, 04:52:04 AM »
FWIW, this is what I have:
Unfortunately, the place I got it from, http://www.gaugeman.com, seems to have gone out of business.  :(
AL GReeNeRy
Oil pressure gauge
« Reply #8 on: January 17, 2008, 06:42:43 AM »
http://flyingbrickperformance.com/cart/index.php?main_page=index&cPath=32_50
those should work for both 325s and 318s.  they also got cheap gauges!
1991 318is : brilliantrot
1991 E30 M42
Uuc
« Reply #9 on: January 17, 2008, 11:17:34 PM »
UUC Motorwerks makes a billet oil filter cap that has two 1/8th npt ports for gauges, and it also comes with plugs so you can use one port or none. On the UUC site it says that the cap only fits E36 & E46 cars but it fits the E30 and I have been using it for about 2 years.
bmwpower
Oil pressure gauge
« Reply #10 on: January 18, 2008, 05:58:45 AM »
Quote from: 1991 E30 M42;41363
Any reason you decided to go with a mechanical oil pressure gauge rather than electrical?
kowalski
  • El\' Duder
Oil pressure gauge
« Reply #11 on: January 18, 2008, 01:40:48 PM »
the uuc one looks really tall... what does the inside of it look like? seems like it might be bypassing the oilfilter if thats all empty space up there.
Sale:
Fore Sale Thread
1991 E30 M42
Oil pressure gauge
« Reply #12 on: January 18, 2008, 11:36:04 PM »
Quote from: bmwpower;41368
I wanted to use Auto-Meter gauges and I also wanted full sweep gauges rather than 90*, and that would have cost me $200 rather than the $50 I spent on the mechanical.
1991 E30 M42
Oil pressure gauge
« Reply #13 on: January 18, 2008, 11:38:10 PM »
Quote from: kowalski;41386
The inside looks very similar to the factory cap but its all machined, and there is no oil filter bypass, it actually clamps down on the filter tighter then the factory unit
kowalski
  • El\' Duder
Oil pressure gauge
« Reply #14 on: January 19, 2008, 01:27:17 AM »
Quote from: 1991 E30 M42;41411
good to know. this is what i shall do then.
thanks.
Sale:
Fore Sale Thread
