Author Topic: Oil pressure gauge  (Read 9872 times)
Wizard
Oil pressure gauge
« Reply #15 on: January 19, 2008, 12:35:54 PM »
Go to you local junkyard and see if they have some older model Audi's or VW's (86-90 models).
Most of these had VDO gauges in them that would read Oil Pressure, Oil Temp and Volts. YOU MUST GET THE SENDING UNITS ALSO. Here is an example (although pisspoor one) of what I mean:
http://cgi.ebay.com/ebaymotors/VW-MK1-Cabriolet-3-VDO-Gauges-Oil-Press-Temp-Volts_W0QQitemZ300190501565QQcmdZViewItem?hash=item300190501565
These gauges look perfect in an E30
BrandC
Oil pressure gauge
« Reply #16 on: January 19, 2008, 10:07:40 PM »
Quote from: ak96ss;41243
FWIW, this is what I have:
Unfortunately, the place I got it from, http://www.gaugeman.com, seems to have gone out of business.  :(
AK96ss: Does this adapter allow you to read both oil temp. AND pressure?
rob_e30
Oil pressure gauge
« Reply #17 on: January 22, 2008, 12:34:06 PM »
That adapter allows you to keep the stock switch and add one additional sender (pressure or temp).  I have the same and use it for pressure.
BrandC
Oil pressure gauge
« Reply #18 on: January 22, 2008, 06:36:34 PM »
Quote from: rob_e30;41528
Where'd you get the adapter from?
rob_e30
Oil pressure gauge
« Reply #19 on: January 23, 2008, 12:00:45 AM »
Same guy that appears to be out of business.  It's pretty simple... a brass block with two female threaded fittings (one for each sending unit) and a banjo bolt to attach it to the oil filter housing.  It's a bit hard to see in the photo, but it's shaped almost like an arrow head with the tip flattend, or perhaps a trapazoid.
1991 E30 M42
pics
« Reply #20 on: January 28, 2008, 07:45:23 PM »
pics
