Author Topic: Oil change gone wrong  (Read 2831 times)
bmuser
« on: January 05, 2008, 12:58:59 PM »
So im chaing my oil, i drained it and i went to tighten the drain bolt back in, as im tightening it up the bolt snaps right at the head.
This bolt i bought when doing my last oil change. I never had this happen before with reused bolts on my previous cars.
Now, does this mean i need a new lower oil pan? This is really frustrating.
Has this happened to anyone before?
Jak318
« Reply #1 on: January 05, 2008, 01:49:12 PM »
I would just drill a hole in it and back it out...
http://www.madelectrical.com/workshop/broken-bolts.shtml
bmuser
« Reply #2 on: January 05, 2008, 01:55:23 PM »
true. im just afraid that the thread is messed up now, and would leak with a new drain bolt.
romkasponka
« Reply #3 on: January 05, 2008, 01:56:55 PM »
you can weld on it another bolt, and screw it out.
E30 318is M42
E36 318is M44
RED IS 91
« Reply #4 on: January 05, 2008, 02:57:16 PM »
I did this when I over torqued my bolt . I used an easy out to get the broken bolt out, then got another bolt from the hardware store to temporarily use while I ordered the correct bolt .
My original bolt was hollow.
I think these bolts are made this way so you can't over tighten them and strip the pan threads . Am I right?
I think the correct torque is 18 ft.lbs.
