Author Topic: Timing chain, loose or not ?? (pics and video)  (Read 7937 times)
nickmpower
« Reply #15 on: January 01, 2008, 01:48:20 PM »
Quote from: Frankie;40234
According to this pic, I can change parts 6, 7 and 14 without messing the timing?
no you would have to remove the chain. You should probably try to get a look at 6 and we can tell you if its been replaced before
« Reply #16 on: January 01, 2008, 02:08:25 PM »
the engine of my friend makes 380hp... not 330hp
« Reply #17 on: January 01, 2008, 02:13:26 PM »
i dont have a picture or a drawing... but it is quit simpel. it is a specialy made screw (no spring inside) that replace nr.17. with this screw, you adjust nr.14. and then you lock the hole thing with another small screw on the side of the new nr.17 so the screw cant turn out anymore.
romkasponka
« Reply #18 on: January 01, 2008, 02:36:44 PM »
can you make a sketch with paint? :)
E30 318is M42
E36 318is M44
« Reply #19 on: January 01, 2008, 03:16:49 PM »
i can try..
« Reply #20 on: January 01, 2008, 03:28:21 PM »
tata...
romkasponka
« Reply #21 on: January 01, 2008, 03:44:38 PM »
Quote from: swiss318is;40286
tata...
Can you ask how to adjust it? How much to tighten it..
E30 318is M42
E36 318is M44
« Reply #22 on: January 01, 2008, 03:50:57 PM »
yep, i have to ask him. when i go to the garage. if i forget it.. send me an email
nickmpower
« Reply #23 on: January 01, 2008, 04:14:52 PM »
what about just taking the existing cap, drilling and tapping a hole in the center of it, then use a threaded rod (a wheel stud seems like it would be about the right length and most of them have holes for a hex wrench) then use a nut on that to tighten against the cap so the rod doesnt move. I dunno how all this would affect oil pressure though
« Reply #24 on: January 01, 2008, 04:27:15 PM »
the piece i am telling, nr.19 and nr.17 ar one piece. so you can screw it in and out and then you can tighten it with the red screw
romkasponka
« Reply #25 on: January 01, 2008, 04:38:17 PM »
The tensioner is oil sprayer too, so there should be oil channel to spray the oil on the chain. Do not forget that nickmpower..
E30 318is M42
E36 318is M44
sheepdog
  • Site Admin
« Reply #26 on: January 01, 2008, 11:11:23 PM »
Remember, that is a race car that is checked over regularly, not just gas added and oil changed every now and again.
« Reply #27 on: January 02, 2008, 04:59:20 AM »
i have only seen this solution on regularly checked engines and cars, such as racecars or special street cars.
Frankie
« Reply #28 on: January 03, 2008, 12:01:32 PM »
Quote from: nickmpower;40266
Hmm, you are saying that its not possible but Sheepdog is saying that it is possible :confused:
« Reply #29 on: January 03, 2008, 01:47:23 PM »
hey frankie: my daily driven car has 240000km on the clock. the timing chain and all the sprockets are like new!!also all the guides like nr 14 and nr 6. !!! no need to be replaced. on this chain is no force (it should not....), like on a bicycle, it only turns around!! i watched your video and i think if you have to pull with such a lot of force to move it about 4-5mm then everything its ok.
if you want to change nr.6 you have to remove the chain, because nr.6 goes behind the chain.. there is no other possibility. for the rest you dont have to remove the chain.
QUESTION: does the noise disappear after a certain time? when the engine and the oil gets warm? what about the hydraulic valve lifters?
sheepdog already say it.. the tensioner fills with oil when it is warm, same the lifters!
