FAQ / REFERENCE
How-To's
Machine m20 flywheel?
Topic: Machine m20 flywheel? (Read 6493 times)
Shift_Now
December 17, 2007, 06:43:54 PM »
So I am aware that you can machine the m20 flywheel so you don't have to use the spacer off teh m42 flywheel. I just got my clutch+flywheel+pressure plate in and I'm wondering if anyone have a picture of where you machine the m20 flywheel. and is there anything you need to do if you machine the flywheel to compensate for the removed material?
Thanks in advance
EDIT: This probably isn't in the right section, sorry.
Last Edit: December 17, 2007, 07:02:53 PM by Shift_Now
rob_e30
Hero Member
-Receive: 1
December 17, 2007, 11:16:25 PM »
So for some lame reason, I can't upload the pics. In any case, the area closest to the center of the flywheel needs to be machined to make room for the bolts that hold the rear seal on. PM me and I'll e-mail the pics if you need them.
Rob.
kramerica5000
December 23, 2007, 04:54:54 PM »
I don't have a picture right off (there's one posted on the forum here somewhere that compares the two flywheels) but the basic idea is just to shave off the lip on the engine side of the flywheel. It should be shaved down so that it's just thick enough for the gear ring. From there you can shave down the interior to cut some weight.
Former *********
Legendary
December 23, 2007, 09:57:32 PM »
Shaving the flywheel and not using the spacer changes the distance from the engine to flywheel face and also the flywheel space to throw out bearing assembly. How does this impact the starter and throw out bearing aspects of the swap?
bosox1134
December 31, 2007, 02:18:38 AM »
i need to replace my clutch and i want to know if i need to remove the exhaust or can i drop the transmission right by it
haledj
Sr. Member
Reply #5 on:
December 31, 2007, 02:23:58 AM »
you don't need top drop the whole exhaust but you need to unbolt the exhaust from the headers and move it out of the way. The back can stay attached.
Buy M42 Coil On Plug conversion brackets!
[/SIZE]
bosox1134
Reply #6 on:
December 31, 2007, 02:25:01 AM »
that sux those bolts are on tight and i have to burn them off
Shift_Now
Reply #7 on:
January 05, 2008, 07:59:23 AM »
Back on topic, does anyone know how much exactly needs to be machined off? And what do you have to do to compensate for the material machined off?
romkasponka
Hero Member
-Receive: 3
Reply #8 on:
January 05, 2008, 01:33:52 PM »
http://www.m42club.com/forums/showthread.php?t=2135&page=2&highlight=flywheel
E30 318is M42
E36 318is M44
Shift_Now
Reply #9 on:
January 05, 2008, 05:15:57 PM »
Oh wow, I can't believe I messed that thread. Thanks
FAQ / REFERENCE
How-To's
