Author Topic: WOW, clean m42!  (Read 17459 times)
AL GReeNeRy
WOW, clean m42!
« on: December 15, 2007, 04:36:40 AM »
wow i couldnt believe my eyes when i first seen this.  hope it isnt a repost
anyone got info on this?!? im positive thats an e30 with an e30 m42, but an e36 m42 mani for boost?? maybe it is better than the e30 m42 intake manifold..
1991 318is : brilliantrot
xsjado
WOW, clean m42!
« Reply #1 on: December 15, 2007, 07:26:58 AM »
OMG it looks sooo nice.....makes me feel like going to the bank and rob some so i can do just this!
nuvolarossa
WOW, clean m42!
« Reply #2 on: December 15, 2007, 09:03:44 AM »
What throttle body is that?:eek:
It bolt-on without mods or I'm wrong?:confused:
WOW, clean m42!
« Reply #3 on: December 15, 2007, 10:18:35 AM »
Quote from: nuvolarossa;39493
+1
WOW, clean m42!
« Reply #4 on: December 15, 2007, 11:07:45 AM »
That looks remarkably like an M30 throttle body.
Quote from: AL GReeNeRy;39489
WOW, clean m42!
« Reply #5 on: December 15, 2007, 12:19:16 PM »
Anybody know what the deal is with the master cylinder angle?
nuvolarossa
WOW, clean m42!
« Reply #6 on: December 15, 2007, 01:52:01 PM »
thank you justin, who know if M30 TB is a bolt-on affair? What is its diameter?
WOW, clean m42!
« Reply #7 on: December 15, 2007, 04:18:09 PM »
Quote from: nuvolarossa;39505
I remember reading 63mm stock and the 633 guys were doing a group buy for 66.x mm bored out throttles.
I don't think its a direct swap because the bottom of the M42 throttle bolts are further apart than the top. But at least we know that the top bolts match up. M30 TB gasket is essentially square.
http://www.autopartswarehouse.com/search/?N=9740+1580+4294967005+7004
VS M42 heater plate as reference.
http://farm3.static.flickr.com/2273/2113768490_0e79cfd0c4_o.jpg
So you will need to use an adapter plate. Maybe a very thin one.
One way to look at it is the that the M42 has a 35mm + 54mm tb or 1.37" + 2.1" TBs. The M42 total thorttle surface area is 1.47"^2 + 3.46"^2 = 4.93"^2. The M30 has a 63mm or 2.48" diameter throttle plate with a total surface area of 4.83"^2. So in rough terms the M30 TB is marginally smaller but thats not the whole story. This doesn't take into account how the air flows through 2 different size TBs instead of one large TB. If you put both TBs on a flow bench I suspect the M30 TB will be more efficient. I'll pick one up at the JY and give it a try.
Another thing to consider the the snorkel that connects the back of the headlights to the airbox is just 2.1" wide at its narrowest point. Using a simple vacuum gauge I measure 5" of vacuum in the lower airbox with the stock snorkel, WOT, 2nd gear @ 6000rpm.  I took that thing off and got an immediate gain in throttle response. No more vacuum in the airbox. Maybe its because I'm running larger injectors so my engine can handle the extra air flow but I think the snorkel is the first restriction to deal with. Right now mine is just a hot air intake until I find a 3" hose to connect to the airbox.
BMW doesn't call it a muffler for nothing. 2" at one end, 3" at the other.
http://farm3.static.flickr.com/2395/2113883286_71ab8b38d5_o.jpg
http://farm3.static.flickr.com/2080/2113883340_98aab2e2b9_o.jpg
« Last Edit: December 15, 2007, 05:12:10 PM by tjts1 »
P. Kennedy
Coils?
« Reply #8 on: December 15, 2007, 06:30:49 PM »
OK, so where is the coil pack?  If it's COP, how did the plastic cover thingy fit on?
strad
WOW, clean m42!
« Reply #9 on: December 15, 2007, 07:23:47 PM »
It appears that the spark plug wires terminate at the battery tray -- I suspect the coil pack is there to keep it away from the heat.
jpod999
WOW, clean m42!
« Reply #10 on: December 15, 2007, 09:08:46 PM »
That intake on the turbo looks pretty ghetto.
nuvolarossa
WOW, clean m42!
« Reply #11 on: December 16, 2007, 03:37:05 AM »
thank you justin. I was thinking that M30 TB was bigger than 63mm just looking pics...
nuvolarossa
WOW, clean m42!
« Reply #12 on: December 16, 2007, 03:38:23 AM »
Quote from: jpod999;39520
Yes, you're right but there isn't space for a great filter in there:D
Cristian G in Oz
It could be an M40 manifold
« Reply #13 on: December 16, 2007, 07:26:52 PM »
Quote from: tjts1;39496
Quote
That manifold could be from an M40 engined car. A mate of mine has an E36 with an M40 in it and it has DISA with the squigley pipes and a round throttle body on it. From the top it looks the same as that fitted to my old M44 Compact. Just a different T/B.
Cristian
1990 318is
WOW, clean m42!
« Reply #14 on: December 17, 2007, 01:33:22 AM »
E36 M40 intake.
http://www.realoem.com/bmw/showparts.do?model=CA31&mospid=47436&btnr=11_0951&hg=11&fg=40
http://www.bmw-syndikat.de/bmw-syndikat/archiv/benzingeruch_m40/2.jpg
E36 M43 intake.
http://www.realoem.com/bmw/showparts.do?model=CA91&mospid=47437&btnr=11_1396&hg=11&fg=40
http://www.gasthai.com/boardgas/picture%5C214255013415.JPG
The top half of the manifold could be from an M43 but the bottom half has to be from an M42/44 because the bolt pattern on the head. The TB still looks to me like it came from an M30.
« Last Edit: December 17, 2007, 09:43:54 AM by tjts1 »
