Author Topic: Removing oil pan  (Read 2535 times)
bmwpower
Removing oil pan
« on: December 01, 2007, 01:35:13 PM »
OK...Bentley says I need to do a bunch of removing/loosening of stuff from the front end to get the oil pan out.  What's the best way to get the oil pan out?  I searched but didn't find anything specific.  BTW, the head and intake are off the car.
« Last Edit: December 01, 2007, 01:39:27 PM by bmwpower »
2002maniac
Removing oil pan
« Reply #1 on: December 01, 2007, 02:19:17 PM »
yea, removing/loosening a bunch of stuff is about right. :D
If you are just removing the lower pan it's as simple as removing all the bolts that hold the lower to the upper.  Go take a look at it and it should be obvious.
bmwpower
Removing oil pan
« Reply #2 on: December 01, 2007, 02:31:54 PM »
Quote from: 2002maniac;38701
I want to remove the whole pan.  I'm thinking of just taking the trans/motor out as one piece.  Thoughts?
The Bentley says remove control arms, lower subframe, etc.  I don't know if I want to be bothered.  Plus, I'd like to do the tranny seals and shifter bushings.  Should make it easier when it's all out.
DZick
Removing oil pan
« Reply #3 on: December 01, 2007, 09:22:28 PM »
You don't have to take the engine out to get the upper pan out.
I just unhooked the engine mounts and jacked up the engine at the tranny, it gave me just enough room to get it out. Although it is a pain getting it back in without the gasket moving.
Good Luck
