Author Topic: list of bushings to replace.  (Read 7803 times)
Adam C.
« on: November 21, 2007, 11:58:28 AM »
i really need to replace all of the bushings on my car, but i dont know what all to get.  is there a list of all the bushings on the car?  i am planning on getting bilstien sports and h&r race, or sports, anything special needed for a lower car? i have some rogue engineering rsm's on my e36, i will switch those to the e30.  i searched and came up with nothing.
thanks
robweenerpi
« Reply #1 on: November 23, 2007, 07:28:41 PM »
Front Control arm bushing
Rear Subframe bushing
Rear diff mount
Rear trailing arm bushings aka silent blocks
Other wear items:
Front Upper strut mounts
Rear shock mounts
Tie Rods
Control arms
That's it, it's a very simple suspension.
Febi Guibo
  • m42 reporter
« Reply #2 on: November 23, 2007, 08:24:43 PM »
well, swaybar links too, while yer under there...
Support M42club.com !!
Adam C.
« Reply #3 on: November 24, 2007, 11:20:59 AM »
thats exactly what i needed!  thank you very much!   will the e36 rsm fit on the e30?
ApocolypseAutoEngineering
« Reply #4 on: November 24, 2007, 04:11:08 PM »
Quote from: Adam C.;38255
No. But if you switch them to greasable urethane it will improve your handling, feel, life, and responsivenees of the suspension. Bmp design has a set that is not too pricey.
E30 FOR LIFE!!!!
Adam C.
« Reply #5 on: November 24, 2007, 08:35:04 PM »
it says here that they are the same:
http://www.rogueengineering.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=RSM&Category_Code=
i think i will just use the ones out of my e36.
2002maniac
« Reply #6 on: November 25, 2007, 12:44:03 PM »
yes, they work.
nickmpower
« Reply #7 on: November 25, 2007, 12:46:47 PM »
get the lifetime shock mounts from bimmer world i think it is. they are like $40
for all the bushings either get stock, or go with ones from akg motorsport. The urethane will be a little stiffer and easier to install and uninstall. Dont get IE bushings they dont fit right
« Reply #8 on: November 25, 2007, 12:53:57 PM »
I've got akg poly ones, and they fit perfectly with little or no loss of ride quality.
Adam C.
« Reply #9 on: November 26, 2007, 09:26:21 PM »
ok, 2 more questions.  should i get 70a or 75d poly?   also, the offset or the regular front CAB's?
« Reply #10 on: November 27, 2007, 04:16:26 AM »
Depends if you have aftermarket suspension or not. If you do then get the offset. As for the poly the 75d is a stronger urethane but prone to squeeking. Plus check if they come greaceable. If they do then all you would need is white lithium greace to fill them with and they won't squeek.
E30 FOR LIFE!!!!
Adam C.
« Reply #11 on: November 27, 2007, 10:36:16 AM »
cant i just put some white grease on there before install?  is there much of a benifit using the 75d?
Oversteer
« Reply #12 on: January 08, 2008, 11:44:39 AM »
Quote from: robweenerpi;38235
You mean item listed as #1?
« Last Edit: January 08, 2008, 01:26:28 PM by Oversteer »
_____________________________________________
Alexandre
\'90 318is E30
« Reply #13 on: January 08, 2008, 01:05:27 PM »
you can hotlink from:
http://bmwfans.info/
Oversteer
« Reply #14 on: January 08, 2008, 01:27:03 PM »
Quote from: dude8383;40718
Thanks!
Alexandre
\'90 318is E30
