Author Topic: oil filter housing-block torque?  (Read 2635 times)
strad
« on: November 16, 2007, 10:34:31 AM »
Sorry for asking -- can't find it either by searching forums or by perusing Bentley.  I'd assume 9 ft-lbs or so (like everything else attached to the block and head it seems), but it's leaking now and I'd like it to not be leaking after I finish installing a new gasket ;)
« Reply #1 on: November 16, 2007, 11:39:27 AM »
IIRC, that is correct - in that area, anyway. I don't think I torqued mine when I reinstalled it, just gave it the 'good-n-tight' spin.
You replaced the o-ring, right?
strad
« Reply #2 on: November 16, 2007, 12:43:25 PM »
I haven't done it yet.  Just to be clear, I'm talking about the 6 or so bolts that fasten the housing to the block.  I have the gasket, but the only o-ring I was aware of is at the canister lid.  Is there another one?
edit: I see what you're talking about now -- realoem no. 8 on the relevant diagram.  Damn, wish I'd ordered that.
« Last Edit: November 16, 2007, 12:46:30 PM by strad »
Vladi
    • http://www.bmwzone.ro/forum
« Reply #3 on: November 16, 2007, 01:44:15 PM »
Judging by the bolt size i'd say maximum 20Nm or do like ak said.
« Reply #4 on: November 16, 2007, 02:55:13 PM »
Quote from: strad;37791
Yep, that's the one. Mine was leaking from that, the gasket was fine.
