Author Topic: Daily Driver E30 318 turbo project  (Read 13635 times)
rob_e30
« Reply #30 on: December 10, 2007, 04:01:29 PM »
Quote from: ApocolypseAutoEngineering;38819
I cut a slit and bent it up so water wouldn't just come pouring in but for now its just to keep the intake manifold temp down a little considering I live in Florida. Eventually I will be fabricating a channel to rout the air to where the turbo will be. Since the turbo is usually mounted high in the engine compartment there is minimal air circulation above the turbo adding unwanted heat to the intake flow and it would help get the air to circulate better in that area preventing a few degrees of added heat and aiding the intercooler a bit.
A less obvious alternative would be to remove the hood seal strip which would help draw air up and out.   I don't think that you'd see much of a benefit at the intake manifold in any case.
« Reply #31 on: December 10, 2007, 05:26:16 PM »
Quote from: rob_e30;39238
Mind you its only for the time being until I drop in the turbo, then it will have a more beneficial use cooling the turbine.
E30 FOR LIFE!!!!
stevohill
« Reply #32 on: December 24, 2007, 03:14:06 AM »
that poor, poor 318... :(
bosox1134
« Reply #33 on: December 31, 2007, 02:40:41 AM »
i think the hood scoop looks great though iwould put mesh or something to get rid of the gap on the bumber
haledj
« Reply #34 on: December 31, 2007, 05:23:55 AM »
Just a few things for you to think about, or maybe you already have.
Why do you want to keep the temperature of the turbo down?
Turbines are more efficient at higher operating temperatures, turbos are designed to run very hot, it is how they work and I do not see any benefit to having more airflow around them.  Cold intake air on the other hand is more important.  I can't imagine any way to draw air from your scoop for intake purposes.
Where is your intercooler going to be that it will see air from this scoop?
 Some subarus use top mounted intercoolers, but there is no space in our engine bays for this.
You may like the looks of the scoop, and that is your own matter and a matter of taste, but I do not think it can be described as functional just because air can get into the engine bay through it.
pbgd3skier
« Reply #35 on: January 09, 2008, 01:31:01 PM »
I think you should work on that scoop more and get it right.
Its like a lazy eye or saggy breast.  With body work its not measure twice cut once.  Its measure 10 times, make a template, use masking tape to line it up precisely, quadruple check those lines, and then finally you are ready to make additions because the human eye is very capable of judging when something isn't centered perfectly.  A purposely off-center scoop such that it would be above the factory air box would be easier to install accurately since it is not an attempt to center, if you know what i mean.
Is it just me or is the bumper higher on the drivers side?
1991 BMW e30 318i
1980 BMW R80/7
