I cut a slit and bent it up so water wouldn't just come pouring in but for now its just to keep the intake manifold temp down a little considering I live in Florida. Eventually I will be fabricating a channel to rout the air to where the turbo will be. Since the turbo is usually mounted high in the engine compartment there is minimal air circulation above the turbo adding unwanted heat to the intake flow and it would help get the air to circulate better in that area preventing a few degrees of added heat and aiding the intercooler a bit.
Just a few things for you to think about, or maybe you already have.
Why do you want to keep the temperature of the turbo down?
Turbines are more efficient at higher operating temperatures, turbos are designed to run very hot, it is how they work and I do not see any benefit to having more airflow around them. Cold intake air on the other hand is more important. I can't imagine any way to draw air from your scoop for intake purposes.
Where is your intercooler going to be that it will see air from this scoop?
Some subarus use top mounted intercoolers, but there is no space in our engine bays for this.
You may like the looks of the scoop, and that is your own matter and a matter of taste, but I do not think it can be described as functional just because air can get into the engine bay through it.
