Author Topic: Welding on chassis, what to disconnect?  (Read 2436 times)
sheepdog
  • Site Admin
« on: October 12, 2007, 09:06:40 PM »
One of my radiator mounts needs to be re-welded.
What do I need to disconnect? I know the battery, what else?
1991 318is
« Reply #1 on: October 12, 2007, 09:13:13 PM »
if it was me i would disconnect the battery and put the ground as close to your weld as possible so the electricity doesn't go another path be for it makes your arc. I'm assuming your are going to mig it? I'm not sure if there is any other things to disconnect.
vitesse
« Reply #2 on: October 12, 2007, 10:34:50 PM »
yup thats all...if you disconnect the negative on the battery you don't need to worry about where you place your ground, but it is always a good idea to keep it as close to your weld spot anyways.  If you have the ground strap right next to your weld spot, you don't even really need to diconnect the battery.
1991 318is: 5 Lug conversion - M brakes - GC track/school 500/650 - (more power here)
1991 318is
« Reply #3 on: October 13, 2007, 12:01:35 PM »
Quote from: vitesse;35640
thats what i was thinking but just to be safe take off the batt.
« Reply #4 on: October 14, 2007, 01:13:57 PM »
I have been bad and never disconnected anything.  I always just made sure the ground clamp was as close as possible to the work site.
