1211 fault code
Author Topic: 1211 fault code  (Read 4622 times)
Vladi
    • http://www.bmwzone.ro/forum
1211 fault code
« on: October 03, 2007, 03:56:41 PM »
I used the pedal test and it turned out 1211 - DME Fault. :D
What's the idea? The engine runs great. :)
RED IS 91
1211 fault code
« Reply #1 on: October 03, 2007, 04:56:11 PM »
1211 is DME control unit
whoops didn't see the rest .
kowalski
  • El\' Duder
1211 fault code
« Reply #2 on: October 03, 2007, 06:41:20 PM »
I just put a haltech in and i have a perfectly good ecu your welcome to buy:)
Sale:
Fore Sale Thread
Vladi
1211 fault code
« Reply #3 on: October 04, 2007, 12:29:21 PM »
You're so kind. :D As i said the engine runs perfect and i'm not changing the ECU because of a light that's probably wrong. :rolleyes:
Stück
1211 fault code
« Reply #4 on: October 04, 2007, 05:22:34 PM »
Its pretty rare to see a 1211 fault, because generally speaking the ECU is bad and cannot output fault codes.
kowalski
  • El\' Duder
1211 fault code
« Reply #5 on: October 05, 2007, 01:30:23 AM »
on a new note, what kind of wheels are those? they look rEAL nice.
Sale:
Fore Sale Thread
Vladi
1211 fault code
« Reply #6 on: October 05, 2007, 12:10:30 PM »
BBS RC's 090 8Jx17 and ET10 with spacer. 5x120. :D
kowalski
  • El\' Duder
1211 fault code
« Reply #7 on: October 05, 2007, 12:26:26 PM »
Quote from: Vladi;35078
:( i had a feeling. Some day i'll do the 5 bolt swap... some day...
Sale:
Fore Sale Thread
Vladi
1211 fault code
« Reply #8 on: October 07, 2007, 04:55:05 PM »
Well no one can do it all at the same time. Some work on the engine and then on looks others the other way around. :)
Vladi
1211 fault code
« Reply #9 on: November 17, 2007, 03:54:54 AM »
Ok so i changed the ground cable between the engine and chassis yesterday and the check engine light turned off (read first post). Drove the car about 10km and it lit up again, throwing 1226. Nice improvement. :rolleyes:
