Author Topic: Improve your cold idle by replacing cracked vacuum tubes and ICV  (Read 9619 times)
kramerica5000
« on: September 23, 2007, 11:32:30 AM »
My cold idle has always been a little off, but it got unbearable after I installed a lightened M20 flywheel and a 93 Octane Mark D chip. The car was much quicker, but when the engine was cold (in summer) it would die within a few seconds of starting. To keep it from dying I had to give it gas for about a half-minute. Then it would idle fine for a few seconds before the revs would gradually drop until the engine almost died and the idle control valve (ICV) would kick in and raise them back to normal. This oscillation would continue until the engine would warm up and then it idled fine.
On inspection I saw that most of my vacuum tubes that live under the intake manifold were cracked. From researching online I also found that a worn out ICV is often the culprit of an unstable idle. I figured the best bet was to replace both the hoses and the ICV since the replacement of both requires the effort of removing the intake manifold.
If your vacuum tubes haven't been replaced, you should definitely inspect them because they dry rot regardless of the number of miles on your car. You can try taping them, but without removing the manifold you can't access most of them, and if you do that, you might as well just replace them.
I think its possible to rebuild your ICV, but for the price I felt it was worth (and more expedient) to go with a new one.
Using RealOem I came up with the following parts list:
(1) 11151739266 Breather Hose
(1) 11151277301 Connector
(1) 13541739248 Hose
(1) 13411721907 Idle speed ctl. hose
(1) 13411721909 Hose
(1) 13411721972 Idle speed ctl. hose
(1) 13411721971 Idle speed ctl. hose
(2) 11151727393 Connector
(1) 11611717761 Intake manifold gasket
for a total of $76.37 from Crevier and
(1) 13411433627 Idle Control Valve
for a total of 137.86 from BMA (about $40 cheaper)
I reused the old hose clamps, so they are not on the list.
I would also add (1) 11151717858 vent hose which I missed and was cracked but I taped and reused.
Disclaimer: I didn't consult a manual so follow these instructions at your own risk.
This job took me about 2-3 hours (could probably be done faster if you know what you are doing :rolleyes:) and I did it in my car-port with just basic sockets, extenders, screwdrivers, and wrenches.
Study this diagram: http://www.m42club.com/forums/attachment.php?attachmentid=381&d=1156043563
1. Start by removing the boot that goes from the intake box to the throttle body as well as the hose that attaches from the boot to the vacuum lines.
2. Remove the horseshoe plate on the front underside of the throttle body (TB) so you can access the studs behind it. Also remove the wiring harness that attaches to TB.
3. Remove the four bolts that attach the throttle body to the manifold via studs, take care not to drop any of the bolts (like I did), they're a bitch to recover once you do.
4. As you remove the TB, remove the three hoses that attach to it and note their locations. Lay the TB to the side on the strut tower, you don't have to remove the throttle cable.
5. Remove the 8 bolts that hold  the intake manifold from the front and the 2 that hold it from the sides (at the plenum)
6. Carefully pull the manifold up off the studs. You'll have to wrangle with the TB heater plates to get them to slide through the opening, or you could remove them completely. I removed the coolant hose from the right side of the lower plate to make it easier.
7. With the manifold removed you have easier access to the hoses underneath. Start removing the cracked hoses, noting their locations and order. To remove you two center hoses that have the U shaped pipe running through them, you will need to remove the 2 coolant hoses that attach to the ends of the U pipe by loosening their hose clamps.
8. With the U pipe removed, note the location and orientation of the two hoses that are slid over it, then remove and replace them with the respective hoses one-by-one. I used a little soapy water to make them slide on easier. On the right side of the U pipe I attached the coolant hose that I removed the the right side of the lower TB heater plate. On the left hose (the end that extends forward) I attached the angle connector and short hose that attaches to the bottom of the TB.
9. Noting its location and orientation, remove the old ICV and switch the mount over to your new one. Attach the top hose that goes the the plenum.
10. At this point you can replace all the old hoses and try to get everything back in the way it was before it came out. The trickiest bit for me was connecting the hose that goes from the right side of the right U hose to the ICV. My approach was to slide the hose into position under the lower manifold then attach it to right U hose. Once you get that in place the rest of it is fairly easy to reattach. Make sure to get everything in place remember to tighten everything before you start putting manifold back on.
11. Re-installation is reverse of removal with the addition of replacing the manifold gasket for good measure. I couldn't find torque specs on the manifold studs, but I don't think they need to be terribly tight. Find torque specs if you can.
12. After getting it all back together, you will need to bleed your coolant system since you opened it up. Start your engine and let it warm up. When the upper hose is warm you can start bleeding it. Have someone rev your engine to 2500-3000 rpms while you open the bleed valve on your radiator. You should see some air come out. Leave it open until only coolant and no air is coming out. Clean up and your done!
Hopefully when you started it up, if everything went well, it started in on a nice smooth steady idle like mine did. After driving it around a bit, I think mine has even gotten better.
I know there are lots of idle issues out there, and this procedure might not cure all of them, but I think its a good place to start.
« Last Edit: September 23, 2007, 11:21:13 PM by kramerica5000 »
sheepdog
  • Site Admin
« Reply #1 on: September 23, 2007, 01:44:39 PM »
I need to do this so badly.
Thinking of hard lining it though.
RED IS 91
« Reply #2 on: September 24, 2007, 05:55:01 AM »
Nice write up. I'd add that when I bleed my coolant system I rev the car from under the hood so I don't need someone else to help me .
Once again ,good write up.
teamgtnfx01
« Reply #3 on: November 24, 2007, 07:57:49 PM »
i joined this forum just so i can say how good this write up is
i have an e30 m42 and it runs like shit on a cold start up and im gonna do this procedure im  am ordering the parts now from pelicanparts the only thing is i dont have the money from the Idle Control Valve i was wondering if this is a bad idea to do all this work and not do the ICV
1992 318 vert with 66k
kramerica5000
« Reply #4 on: November 25, 2007, 12:02:17 PM »
I just wanted to replace both because I didn't want to have to pull the manifold again in case it the ICV turned out to be bad (though it's not all that big of a deal). What you might do is look into rebuilding the ICV yourself. I think it can be done fairly easily; I found an write up on it somewhere on google ... I'll post it if I can find it.
Quote from: teamgtnfx01;38286
teamgtnfx01
« Reply #5 on: November 25, 2007, 12:31:06 PM »
i dont know what ever if i have to pull it off agian im gonna do that because i cant afford  another buck 50 for the ICV right now mayb another time
also i found a kit from pelican (to rebuild the ICV) its like $100 might as well buy a new one
and thanks again for all the tips i love this write  up
and did u do ur fuel lines while under the intake manifold
strad
« Reply #6 on: November 26, 2007, 10:06:55 AM »
I did the fuel lines and everything else rubber while I was under there.  If the ICV dies (and it might lol) I'll take the manifold off again.  The gaskets are cheap, and I know how to get the mani off quickly now.
teamgtnfx01
« Reply #7 on: November 27, 2007, 10:03:46 PM »
Quote from: strad;38359
whats the way of getting off the manifold quickly because im planning on doing it next weekend or whenever my parts come in
pbgd3skier
« Reply #8 on: January 12, 2008, 01:19:40 PM »
leaky vac. lines also allows your engine to suck air that isn't metered and therefore results in a lean condition.
1991 BMW e30 318i
1980 BMW R80/7
unmole30
hoses!
« Reply #9 on: April 09, 2009, 09:46:36 AM »
alrite guys, on my m42, the guy (fool) who i baught it off had blocked off loads of hoses and done some silly stuff, the breather hose that comes of the cam cover and been cut and he had put a brether filter thingy on it, the cone type, i wanted to take that off and reconnect hoses how they should be, so can any 1 tell me the following:
1. where does the breather hose connect to of the cam cover
2. what should be on the hose under the throttle body
3. what connects to the connector under the big air hose that connect the air box to the thottle body
4. what connects to the ICV .hose.
i had a look at the diagrams on here but could not make anything out of them, any pictures of your engines?
cheers
///m42 sport
« Reply #11 on: April 10, 2009, 01:01:35 PM »
Or this if you don't like reading :)
http://www.m42club.com/forums/showthread.php?t=6334
