Author Topic: engine acting weird :confused:  (Read 3432 times)
FL318i
« on: September 10, 2007, 10:56:17 AM »
hey there, for some reason when i start the engine and its cold the car sputters until it shuts off if i dont give it gas and i noticed that when it does that the check engine light comes on but if i rev it up stops the sputtering.
any clue what can be causing this>>>????
" ....and the little brown fox jumps over the lazy dog... "[/SIZE]
FL318is
« Reply #1 on: September 10, 2007, 03:20:39 PM »
I am not a mech or tech but could it be the idle control valve.
http://www.realoem.com/bmw/showparts.do?model=AF91&mospid=47256&btnr=13_0307&hg=13&fg=15&hl=15
item #7
FL318i
« Reply #2 on: September 10, 2007, 04:19:18 PM »
thanx for the reply, i dont know if thats the problem but i'll chek it out
btw, do you know where is the IAT located on our cars???
ten2doyle102
« Reply #3 on: September 11, 2007, 05:29:19 PM »
does the car's rev's bounce when its idling?  I could be a bad vacuum leak as well.  my car has one somewhere and the check engine leak comes on and turns off when i give some gas.
since we're on the subject...what are some good ways to find vacuum leaks?
christophbmw
« Reply #4 on: September 11, 2007, 07:16:21 PM »
....leaking injector maybe? whats the code?
FL318i
« Reply #5 on: September 11, 2007, 08:30:26 PM »
no idea what it is, its doing it when i start the car and at the same time it sputters the check engine light comes on but when i rev it it stops and then idles fine after a few good revs:D
didnt do a diagnose yet!!!
RED IS 91
« Reply #6 on: September 21, 2007, 10:08:33 AM »
Quote from: FL318i;33560
Have you checked the ICV yet ?????
FL318i
« Reply #7 on: September 21, 2007, 09:55:52 PM »
icv= ??? whats that??? sorry kinda newbie with the short names
RED IS 91
« Reply #8 on: September 22, 2007, 07:36:27 AM »
Get a bentley manual if you don't have one already. It is the bible for these cars.
And search is your friend.
good luck
