Author Topic: sway bar tabs  (Read 2981 times)
sha1234
sway bar tabs
« on: September 09, 2007, 02:45:53 PM »
well the rear control arm tab where the sway bar mounts up has broken off... even after i bolted down the re inforcment tabs... so i picked up the TMS tabs that should be weldered....
BUT... since the rear control arm is apparently... cast? should i weld it a certain way... use a different gas or wire?
has anyone welded on this tab?
sha1234
sway bar tabs
« Reply #1 on: September 09, 2007, 04:55:01 PM »
never mind... figured it all out... its a stamped peice so i can just weld her all up
