What is the lift on stock cams?
What does "10,4mm and 1,2mm" mean? Is that the lift? I'm not sure what that last number is.
The most important thing to find out about the cam is at what degree it is 10.4mm and for what duration. Give me some more specs if you can, compare it to stock, and we'll see if they are worth the money.
Max lift = 10.4mm @ 110° ATDC (After TDC)
Lift at TDC during overlap = 1.2mm
These numbers will not tell you much, different cams with the same data can have different lift rates. This cam might lift 4.6mm @ 65° ATDC. While another might lift 5.7mm @ 65° ATDC. (random picked numbers, for illustrating a point)
I'm a bit suprised you ask what the numbers mean, when you wrote this line above:
Post the lift characteristics and then I can tell you.
Here is a comparison between stock intake, and Schrick intake:
